wont start
Old 12-23-2007, 07:21 AM
da6jdmteg's Avatar
Default wont start
i have a 88 4dr ef. mods are p29 pistons. 95 si intake manifold. gude cam. aem cam gear. aerospeed fpr. venom fuel pump. the car ran before the build. now its together it wont fire up. i got spark and fuel. and moved the timing around all different ways. my main relay is working and so is the ecu as i tested those in another car. what left is there i can try.
Old 12-23-2007, 07:32 AM
black0hatch's Avatar
Default Re: wont start (da6jdmteg)
is there compression?
Old 12-23-2007, 03:52 PM
da6jdmteg's Avatar
Default Re: wont start (black0hatch)
yes there is compression.
Old 12-24-2007, 06:54 PM
2slow4stock's Avatar
did you check all the grounds?
Old 12-25-2007, 09:16 AM
da6jdmteg's Avatar
Default Re: (2slow4stock)
as a matter of fact i did have the ground loose to the thermostat. im not sure if i hooked that back up. i think i did. not positive. ill check that out.
Old 12-28-2007, 09:37 PM
Marcos Barrios's Avatar
so did you
Active EF
02-21-2015 08:56 PM
jweeks
07-14-2008 04:35 PM
b16a4
04-26-2007 06:21 PM
cyco
11-22-2005 02:41 PM
t3to4e
01-07-2004 05:00 AM
Quick Reply: wont start
