what are these two plugs?
Im installing a rywire budget b harness in a 1990 civic si. I have relocated my fuse box inside the car during my install. Im left with one question. I have a small 2 wire plug next to what i believe is my MAP connector that i dont remember. Also, i am missing a small connector to my fuse box. Can anyone shed some light?
The first picture shows the small connector i dont remember next to the (i think) MAP connector. The second image shows the spot on the fusebox where i am missing a connector just right of my thumb. What are these 2 connectors and should i worry about the missing one?
Re: what are these two plugs?
First picture the two wire plug is for the purge valve and the second plug three wire is map sensor.
Now the fuse box part that is for the Hazard lights/ELD detector.
anyone else?
anyone else?
Do you happen to know where that connector for the hazards runs? Like, does it run into the driver side harness or passenger side? Wire color?
DOMAN!EJ8
16
09-02-2009 10:17 PM
