how canister works ?
i would like to know :
-in what situation gases goes to the intake manifold
-in what situation gases goes to the throttle body
when is the purge solenoid valve closes or open ?
thanks
thanks
Keyboard Humorist
Re: how canister works ?
Vapors only release into the intake after operating temp has been reached and while the engine is driving - not at idle.
Into a port on the intake manifold? Never.
The line on the top of the canister gathers fuel vapors from the fuel tank mounted 2-way valve.
Also on top of the canister, there is a flat disc which is a valve. The top line goes to the purge cut solenoid.
When the ECU triggers the solenoid, vapors are introduced to the engine through the bottom line on the disc/valve and into the throttle body port.
The hose coming out of the bottom of the canister runs back to the fuel tank carrying liquid fuel.
what happens if i remove the purge solenoid valve and connect directly to the intake ?
i have a JDM TB that does not have the canister spaout. if i dont connect the canister to TB, to where the canister will release the vapors ?
longest project ever
Location: on the south side of dixie, 1986 Accord Hatch
Keyboard Humorist
Some systems have that hose venting to atmosphere and others route that back to the tank.
Been a while so I really can't say for sure what that hose is on these cars.
once the valve opens then vacuum is applied at the top,allowing air to start to flow through the canister,evaporating the fuel stored in the charcoal, and it's then pulled into the engine and burned
Keyboard Humorist
They cap the port on the throttle body and route the vapor line from the gas tank down the firewall.
Vapors just go out under the car.
If you want to be environmentally friendly and keep the system, maybe you can add a tee fitting to one of the other lines coming off the manifold?
A lot of people remove the canister and solenoid.
thanks a lot for the information,
i made a test , a drive with cold engine, i connected the canister to the intake with out the purge solenoid valve, and didnt notice any thing different
When fuel evaporates inside the gas tank, the excess fuel vapors are transferred to the charcoal canister. The way the EVAP purge valve suppose to operate is to open while driving, so the engine can suck/purge fuel vapors out of the charcoal canister and use that to be burned with the normal air-fuel mixture.
If you connect the line from the canister without the EVAP canister purge valve, the car may become flooded during refueling. During refueling without the purge valve, even more fuel vapors are allowed to enter the intake manifold and your car can become flooded. Pressing the accelerator pedal gets the car to start from the flooded situation. With the canister purge valve installed, the valve should normally be closed during refueling.
OP post a picture of your canister, you said it doesn't have a purge control valve? remember if you vent it to air, thats also letting fuel evaporate out of your tank, gas prices may have gone down, but they will go back up, and that's venting money basically, forget the environmental stuff, thats gas evaporating you could be using in your car,
this is what i have now.
i have netuneRTP and on log now i know that the PCS is open util ECT-74c, after ECT-75c PCS is close
EDIT:
i dont know if the check box is open or close
EDIT:
RiversideS13
07-18-2007 11:08 AM
