Need Help B16a Oil Leak
I have a small oil leak coming out of the corner of the head. Is this common for the b16? I've changed VTEC solenoid gasket, Distributor O-ring and it seems to seep after I drive around. I'm gonna assume I need to change the head gasket?
Re: Need Help B16a Oil Leak
You could replace the head gasket, but unless its leaking bad I wouldn't worry too much. I have heard of some engine builders applying a very small amount of Hondabond to this area when putting the head on.
very common for dohc vtec engines.
replace head gasket, in the mean time, just mind your oil level. although this wont drop it much...
I think evey b series i ever got my hands on leaked there. I wouldnt worry too much about it. When you want or need to replace the headgasket just make sure you add some hondabond in that corner to both sides of the headgasket. Otherwise for the time being, you could wash it very well leave it sit for a few days and try to get some sealer around there. Getto yes, but I have seen it work for quite awhile.
Did you make sure to replace both gaskets on the vtec solenoid? I had a small leak in the same place and it was dripping from the top of the solenoid, nothing major but was noticeable.
I replaced the gaskets for the VTEC Solenoid! It was originally leaking there, now the oil is seeping thru the corner of the head
Vietnamese!
Very common problem....change head gasket if it continue to leak at the same spot then you should get your head resurface at the shop.hope this helps
Dude seriously don't even bother about changing your headgasket believe me i just went trough the whole thing also thinking it could be something wrong i guess is normal for b series like everybody says i spent money i wasn't suppose to and still leaking every once on a while so is normal.
Its not your headgasket. I'm telling you that right now. If it was your car would run like crap. You have two seals on the vtec solenoid, and the cam cap, and the distributor o ring. Are all your bolts on the dizzy? It's one of these parts that I have named is your culprit. did you get an aftermarket cam cap?
I'm positive that the leak is coming from the head..I changed all the gaskets except for the head. I don't see any leaks in those areas and yes all the Dizzy bolts are intact.
Cam cap is the most common oil leak problem on every VTEC b-series on the planet.
Hence the multiple gasket ones, etc.
Hi guys,
I am from Europe - Romania.
I have the same engine (b16 gen1) and the same problem. I have changed all the gaskets in that area (distributor, cam seal, vtec, etc.) and the head still leaks in the same place as in the picture above.
two days ago I have changed the head gasket also and I have redone the surface of the cylinder head and the problem is still there. now is not leaking that bad but it still leaks.
I think that the very good way to solve this problem is to redo the surface of the blok also...
thank you.
thank you.
I had a '92 Integra...same engine, very similar prob. If I remember correctly, the leak was mainly from the dist, seal. I really wouldn't call mine a 'leak' because there was no preceivable oil loss, even at 200k. I also seem to remember the valve cover screws needing a little tightening on occasion, but I never bothered using a light ThreadLock.
In short, it should not pose a problem, mechanically.
Best of luck!
Best of luck!
What kind of Oil are you running? I was running Mobil one in my D series until i noticed that it was leaking oil in the same spot that your B engine is. I switched back to dino juice and no more leaks.
Having the same problem i think. Not savvy with cars. I might need help with the jargons. I attached the photos where my leak is coming from. I just had an engine wash and before that the leak was so thick that dust and dirt mixed with it. Though my car is working fine. Just that i have that leak.
Pretty much what everyone has said over the years sums it up. Something you're going to have to get used to. I replaced the distributor o-ring, vtec solenoid gaskets, cam seal, and headgastket. Went away and came back. I'm sure it was coming from the o-ring as when I replaced it, the leak stopped, but slowly came back. I just stopped caring and if it annoyed me too much, cleaned it off with brake cleaner.
Cameronphelan
Honda Civic (2001 - 2005)
05-29-2015 10:23 AM
