Temperature Sensor Problem
my crx have a check engine light bcuz of my temperature sensor. my motor bog wen i rev it up, it does have gas but im guessing it might be some electrical problem.
how can i fix it?
how can i fix it?
Re: Temperature Sensor Problem
Dont forget to check the plug for the cts because the wires could be touching in the plug. Thats what was wrong with mine. But like N3va3vaSatisfi3d said, check the sensor first.
damn i check the coolant temp. sensor and the plug got disconnected from the wires(probably normal wear and tear). well im going to go to the junk yard and get some coolant temp. sensor and plugs...thanks for the info...
