HID's when turn on makes idle splurge?!?!?!?!?!
recently for some reason when i turn on my hids it makes the motor bog, some times shuts off, or rpms jump to try and keep it running. Plus the hids usually wont come on or will flicker for a second but the idle will still be messed. even if the hids didn't kick on. any ides?
Re: HID's when turn on makes idle splurge?!?!?!?!?!
Check your battery and see if your getting the right voltage.if it's good check your alternator
be a n e r
x2 on the batt volage and alternator
Hid's are illegal cause your stock housings aren't made for em.hid's have to come oem on your vehicle
To be legal.
So if your car didn't come stock wit hid's from the factory then there ILLEAGAL!!!.but anyways i still use em and just point em down until i get a retrofit
Haha
To be legal.
Haha
you may need to check the ballast boxes on your hid kit and check to make sure they are tranfering the voltage properly. Hope it helps
To be legal.
Haha
To be legal.
Haha
And I was answering the other guys question cause he was tryin say white hid's are legal
ended up being the negative battery terminal. Is was corroded. cleaned it up, everythings better. Thanks for your help guys!!!
94DelSolVTEC
02-24-2002 09:32 AM
