greddy turbo comp. wiring?
Does anyone have the wiring diagram for the greddy turbo computer? the car is a 97 gsr. It has a v-afc that the guy wants to use to tune the car. Will the computer work properly if the v-afc is installed? please We need help!!!!!
HELP! HELP! HELP!!!
actually here is the real problem... the owner of the car is a customer of mine, and he had this turbo installed by someone that had no idea what was going on! the v-afc and the GREDDY blue-box were both wired together and the car ran like s@#$. i decided to eliminate the blue-box and use only the v-afc, but now the car falls on it's face as soon as you get into boost. is this a tuning issue, or do i need to re-install the blue-box? and if i do need to re-install the blue-box, does anyone have a wiring diagram that could be emailed or faxed to me? SOMEONE PLEASE HELP!!!
Re: HELP! HELP! HELP!!! (SoloSol)
reinstall the blue box, you're probably throwing a MAP code when it hits boost since the ECU now sees an out of range signal from the MAP because you took out the blue box. Diagram is there, hit reload a couple times if it doesnt load
http://www.geocities.com/wo0ng/public/FCU.jpg
if you plan on wiring the VAFC with it, its no biggie, just wire the VAFC between the box and the ECU
[Modified by woong, 1:35 AM 6/21/2001]
Snail Tuning
06-03-2008 04:45 PM
