Will drag 3 GSR fit all b-series motors?
Better than steak
What I really want to know is if there is a difference in the height of the long block on a b18c Vs. B18A 93 Ls? Can I just use the same downpipe that came with a drag 3 Gsr on a B18A 93 Ls? Will it clear the oil pan.
I know that the Gsr and ITR are 270mm, but I dont know the B18b or the b18A. Can someone clear this up?
TIA,
art
[Modified by Arturbo, 9:33 AM 6/23/2001]
TIA,
art
Re: Will drag 3 GSR fit all b-series motors? (TurboR616)
The only modification that you might need to make is how the IC piping is bent near the intake manifold - it should be the same reason that LS or GS intakes don't fit on GSR's and vice-versa. Other than that, TurboR616 is right.
Someone correct me if I'm wrong.
