Soft Rev Limiter - MSD?
Old Jun 18, 2001 | 12:35 PM
lundgren's Avatar
Default Soft Rev Limiter - MSD?
I was looking to "fix" the rev limiter, so it's not a fuel cut off, but an ignition cut off, or something like the Soft Rev Limiter the MSD Ignition Provides?
In auto-x, I don't like bumping off the rev limiter, I know it cannot be good with the JRSC.
Options? Please advise me.
Old Jun 18, 2001 | 01:36 PM
VaporTrail's Avatar
New User
Default Re: Soft Rev Limiter - MSD? (lundgren)
I've used the MSD soft touch box. It's very nice. You can buy the Soft Touch box seperate of the MSD if you wish to avoid the headaches and pit falls of a MSD6AL. It's 99 bucks from Jegs. Works great!
Old Jun 18, 2001 | 02:17 PM
TurboInteg95's Avatar
soft limiter is pretty much the Sheezy, I'm not a fan of cutting fuel at redline on full boost.
Old Jun 18, 2001 | 02:30 PM
lundgren's Avatar
Default Re: Soft Rev Limiter - MSD? (TurboInteg95)
What is "Sheezy" ?
Old Jun 18, 2001 | 02:44 PM
lundgren's Avatar
Default Re: Soft Rev Limiter - MSD? (VaporTrail)
VAPORTRAIL:
Is this it http://www.jegs.com/cgi-bin/ncommerc...%202400%202402 ?
Old Jun 18, 2001 | 04:09 PM
sorry, I guess it's kind of an inside thing. same as saying it's the ****. hehe
Old Jun 18, 2001 | 09:09 PM
CIVICHB_SC's Avatar
New User
i use the msd 6alW/soft touch, it works great. plus it's added insurance.
Old Jun 18, 2001 | 10:30 PM
VaporTrail's Avatar
New User
That is the unit indeed. Make sure you buy pills also, because the ones that come with it are about as useful as **** on a tire. I recommend MSD pills, far more reliable than any others I've tried.
Old Jun 19, 2001 | 06:01 AM
lundgren's Avatar
Pills?
Old Jun 19, 2001 | 07:13 AM
G's Avatar
G
VaporTrail, what's wrong with the 6AL? You guys can use a variable resistor instead of buying pills. If I remember correctly, you'll need a 1K ohm linear taper potentiometer or varistor. You can use the supplied 3000 rpm limiter for a staging limiter and the varistor for rev-limiter using a simple push-button switch.......
Old Jun 19, 2001 | 10:58 AM
VaporTrail's Avatar
New User
Pills?
Pills are the plug in modules that decide the rev limiter. Example - you want your rev limit to be 8500rpm, then you would put in the pill that reads 8500 rpm.
Old Jun 19, 2001 | 11:09 AM
lundgren's Avatar
But the ECU rev limit is 8100, so if I put it to something higher than that, the ECU would have already tried to cut fuel off... so the 8000 one included is most likely ok.
Old Jun 19, 2001 | 11:18 AM
VaporTrail's Avatar
New User
You got it now. The best combo would be a removed rev limiter, using the soft touch box to limit the revs alone.
Old Jun 19, 2001 | 12:00 PM
lundgren's Avatar
How do I 'REMOVE' The rev limit ?
Old Jun 19, 2001 | 12:40 PM
if I"m not mistaken when they "remove" a rev limiter on honda ECU they actually just put it way out to like 15000 RPM so you'll never hit it.
Old Jun 19, 2001 | 12:46 PM
VaporTrail's Avatar
New User
you'd have to have the ECU chipped.
Old Jun 19, 2001 | 01:01 PM
lundgren's Avatar
I really don't think having the rev limit (soft limiter) at 7900 is all that bad. Sure the hp on the dyno won't be as high, but it will be safe. The NA guys would hate it, because those cars are fast, because they stay in lower gears longer, but with FI, that's really not an issue, and I'd rather run it safer.
And that's what I thought, I'd have to fix it at the ECU.
90tegboosted
Engine Management and Tuning
May 24, 2013 04:31 PM
maxboost_50psi
Dec 1, 2005 09:43 PM
CIVICD16A9
Jul 4, 2005 08:26 AM
EVOCELICA
May 21, 2002 11:01 AM
Rhetoric
Dec 16, 2001 12:05 PM
