can a Greddy turbo for GSR be modified to fit.........
New User
a del sol engine?
an LS engine?
a b16a?
these are all questions ive been asked while selling my turbo.
an LS engine?
a b16a?
New User
Re: can a Greddy turbo for GSR be modified to fit......... (Optimus Prime)
yea the manifold would bolt to the ls engine and b16a, just other stuff would need to be modified ex. downpipe, intercooler piping. I'm not sure what engine del sol's have i think itz a D-series. well the GSR turbo kit, the manifold could bolt up to all B-series motors.
it would depend on what model Del sol. if it's the one with B16 then it would fit. it will fit on an LS also. you'll just have to modify the piping a bit here and there.
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
i have a 93 hatch with 95 ls motor and tranny. i put the 95 gsr greddy intercooled kit straight on. i did not have to hack and mod any of the pipes EXCEPT the downpipe and lightspeed cat(also gsr). they have to be extended and that depends, but other than that everything else should bolt right together. you will have to fab two brackets if you want to support your intake and t.b. charge pipes which isn't necessary. i am in the process of trying to find out if i can use the blue box and injectors with my 95 ls computer.
E-spec Tuner
09-16-2003 08:30 PM
