compression numbers(2)
Old Jun 18, 2001 | 04:48 PM
quikrpm'z's Avatar
Default compression numbers(2)
i took the car back to the shop that dropped in the engine, they did a compression check and got 165 across all cylinders. Wtf....
the only diff from his check to mines was that the engine was real hot, and he cranked it like 10x's.
just to refresh the memory i got, 185 on three and 160 on one cylinder. I cranked like 7x's. I dont know what to think now.
Old Jun 18, 2001 | 04:53 PM
LsTurbo91's Avatar
Default Re: compression numbers(2) (quikrpm1)
yea i think its suppose to be at normal operating temperature. Did you do it when it was cold? Damn 10x ? what kinda of motor is this LS ?
What is your vacuum at idle ?
[Modified by 9psiLsT, 5:53 PM 6/18/2001]
[Modified by 9psiLsT, 5:54 PM 6/18/2001]
Old Jun 21, 2001 | 11:39 PM
quikrpm'z's Avatar
Default Re: compression numbers(2) (9psiLsT)
vacum at idle is 50.
Old Jun 22, 2001 | 12:52 AM
greyzone's Avatar
uhhh, that should be 17 to 20...
Old Jun 22, 2001 | 05:12 PM
quikrpm'z's Avatar
Default Re: compression numbers(2) (greyzone)
what should i check,and what does my current reading indicate?
Old Jun 23, 2001 | 01:22 AM
Ray's Avatar
Ray
New User
vac. at 50? mine is at 20. Something is wrong cause 50 is way off.
Old Jun 23, 2001 | 12:52 PM
quikrpm'z's Avatar
Default Re: compression numbers(2) (Ray)
help??? 96rs
[Modified by quikrpm1, 1:54 PM 6/23/2001]
Old Jun 23, 2001 | 04:38 PM
quikrpm'z's Avatar
TT
Old Jun 23, 2001 | 07:59 PM
Ben Huynh's Avatar
A variance of 10% is OK.
350znal
Feb 14, 2011 04:12 PM
1epmugenlude
Jan 8, 2006 05:47 PM
drewcandraw
11
Jun 5, 2005 12:21 AM
Swift_asian
Jan 28, 2004 09:09 AM
98lude
Jul 27, 2001 07:29 PM
