how much for a conquest intercooler????
Old Jun 24, 2001 | 03:20 PM
prjctCIVIC's Avatar
Default how much for a conquest intercooler????
i plan on purchasing a used one, but how much should i expect to pay??? and what should i look out for before purchase? thanks
Old Jun 24, 2001 | 03:56 PM
4dGSR at work's Avatar
Default Re: how much for a conquest intercooler???? (prjctCIVIC)
ok if your lucky and it is NOT on ebay you might get it for 80-100 but i would not pay more then hmmmmm180.00. just make shure you know if it is pressure tested. from the dealer brand spank'n its 809.19....for just the IC!!!
Old Jun 24, 2001 | 04:26 PM
prjctCIVIC's Avatar
Default Re: how much for a conquest intercooler???? (4dGSR at work)
how do you pressure test it?
Old Jun 24, 2001 | 10:00 PM
TurboMiata's Avatar
You basically feed pressure through it and listen for leaks. If you can't hear any leaks, it doesn't mean it doesn't have any, however, any leak so small you can't hear isn't really important anyhow. I have a starion intercooler (same as conquest) and I paid $130 on Ebay some time ago. Junkyards would be cheaper than Ebay though.
Old Jun 24, 2001 | 10:42 PM
R6Boy69's Avatar
Default Re: how much for a conquest intercooler???? (TurboMiata)
I got mine for 130 off a guy on this board.
Old Jun 24, 2001 | 10:48 PM
prjctCIVIC's Avatar
what tool do you use to test the presure?
Old Jun 25, 2001 | 08:41 AM
TurboMiata's Avatar
an air compressor should be good enough. Just find a way to block the other end of it so that air can't escape, then find a way to seal the side with the air compressor so that the intercooler is air tight.
fwiw, since honda's use MAP sensors (correct me if i'm wrong someone) it really shouldn't matter much unless the hole is freaking huge because the turbo will just spool a little more to compensate. I'm just telling you this because most people won't even bother with you if you tell them you want it pressure checked first. Large pictures, from every angle *should* suffice.
Old Jun 25, 2001 | 08:43 AM
brcivic411's Avatar
I have one for sale... $150 shipped. email me if you want the picture. it's in good condition.
rollagti
Feb 29, 2008 01:22 AM
SpleenBoy
Sep 21, 2006 09:27 AM
k4rts
Jul 21, 2006 10:18 AM
raiden571
Sep 14, 2005 06:35 PM
