What's the advantage of a bigger fuel rail?
New User
Re: What's the advantage of a bigger fuel rail? (Jared)
not to much.
they are mostly for looks
a stock will sute your needs fine.
but to look the best go wit the bigge
The larger bore reduces pulses in the rail when using LARGE injectors at low pressures.
You will not need one until you exceed 15psi of boost.
the.hamburglar
07-14-2007 12:01 PM
