how do check valves work ?
Old Jun 23, 2001 | 06:59 PM
D-SPEED's Avatar
Default how do check valves work ?
how do they work ? is it the same thing as a bypass valve ?
Old Jun 23, 2001 | 07:44 PM
Ben Huynh's Avatar
Default Re: how do check valves work ? (D-SPEED)
A check valve is a one way valve. It is normally used to bleed boost before it reaches the MAP sensor. A bypass valve is spring loaded and evacuates boost when you let off the throttle.
Old Jun 23, 2001 | 07:58 PM
D-SPEED's Avatar
Default Re: how do check valves work ? (ben@importparts.com)
sorry i did not mean bypass valve as in bov......
i meant like......what is the "missing link" product ?
Old Jun 23, 2001 | 08:16 PM
Ben Huynh's Avatar
The Missing Link is a high quality replacement for the plastic check valves.
Old Jun 24, 2001 | 11:24 AM
D-SPEED's Avatar
how does it work ?
Old Jun 24, 2001 | 11:37 AM
Jared's Avatar
When boost is applied to the check valve, it opens and the boost escapes to the atmosphere before the MAP sensor can read it. When the car is under vacuum, the check valve is closed(read one way valve) and allows the MAP sensor to read regular vacuum.
later,
Jared
Old Jun 24, 2001 | 01:33 PM
LudeSi-93's Avatar
New User
Default Re: how do check valves work ? (Jared)
I've always wondered about that concept. If it's bleeding boost into the atmosphere so that boost won't reach the map sensor, isn't it kinda like a boost leak? Cause I know on an RX-7 if you have a boost leak, you're basically losing boost and won't make full boost, so in order to make full boost, basically your turbo has to work a little harder to make up for the leak?? I'm not sure, so please explain.
Old Jun 24, 2001 | 02:16 PM
Jared's Avatar
Default Re: how do check valves work ? (TurboLudeSi)
You are correct. It is a boost leak. I'm sure you could fix that by taking the outlets of the check valves, combining them, and routing it back into the manifold. However, it is a small boost leak, only what will flow through the check valves.
later,
Jared
Old Jun 24, 2001 | 04:44 PM
TurboInteg95's Avatar
yeah basically a small leak but not a big deal. You can make an electronic check valve so to say. since the MAP sends a voltage to the computer that's dependent on the manifold pressure you simply make a circuit that doesnt allow the ecu to see anything more then 2.9v approximately. I dont really know all that much about electronics but G from the board is going to let me try one on my car that he made.
Old Jun 24, 2001 | 06:12 PM
D-SPEED's Avatar
Default Re: how do check valves work ? (TurboInteg95)
that seems like the simple solution.......why hasnt this been done before ? i hear alot of people say they dont like the check valves....
Old Jun 24, 2001 | 06:57 PM
LudeSi-93's Avatar
New User
That is it, I'm going to make that electronic device that will regulate pass-through voltage from 0-2.9V. I didn't know it was simple as just the voltage. My major at UCSD is electrical engineering. That entire device is just capacitors, diodes, and BJT transistors!! I've made something like that already. That is it, time for some schematics!!!
Old Jun 24, 2001 | 07:24 PM
you'll want to check your MAP voltage at atmospheric pressure first, they're all slightly different. for example mine was 2.9, G's was 2.82 or something like that. Just turn the car on without starting it and check the voltage that the MAP is giving out, should be high 2's.
hatchedzex
Jul 18, 2004 05:47 PM
luderone
Sep 30, 2003 09:14 AM
crx1856
May 19, 2003 10:44 PM
technine
Aug 8, 2002 02:52 AM
