Maximum boost with J&S and drag3 in ITR?
Anyone know what the maximum boost would be if I added a J&S safegaurd to my drag3 turbo type r setup? I have been at 8 lbs. for a year now and the car never detonates. I have the MSD boost retard module, but I have never had to touch it.
[Modified by blackitr730, 12:39 PM 6/23/2001]
I wouldn't recommend going any higher than 9 PSI on the stock engine. Maybe a little more at the track if you plan on using the timing retard module. The compression on the ITR is so high, that I don't think it'll be a good idea to raise the boost with the stock engine, that's if you have the stock engine. With the J&S, it'll do a really great job as to detecting detonation, but still if your engine is not built up, I wouldn't recommend gonig TOO high.
When you're testing the boost limits of your engine, please remember to increase boost incrementally and please do so using race gas.
pjr710
Jan 5, 2009 11:15 PM
