Fuel Pump
Old Jun 15, 2001 | 07:44 AM
mod5's Avatar
Default Fuel Pump
This is currently my engine setup: ('99 GSR)
GReddy Turbo Kit w/ IC (7lb-8.5lb BOOST), EVO exhaust system
MSD SCI Ignition System, SS Blaster Coil, Pro Cap (distributor)
Nology Hotwires (spark plug wires)
Iridium IK24 spark plugs
I am looking for a GOOD fuel pump? intake or inline? or do I need one at all?
Old Jun 15, 2001 | 07:50 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Fuel Pump (pornstaR)
Not if the kit came with the injectors and the Blue box.
art
Old Jun 15, 2001 | 08:12 AM
mod5's Avatar
Default Re: Fuel Pump (Arturbo)
The GReddy kit did come with the Blue Box and 310 injectors... So I shouldn't get the fuel pump? why not?
What about a FPR?
Old Jun 15, 2001 | 09:07 AM
TurboInteg95's Avatar
you dont need any of it, the kit is made to run on stock fuel pump. You could however upgrade to a Walbro 255 lph for added safety if you wanted to. it will work fine for your application since the blue box compenstes through injector pulse.
Old Jun 15, 2001 | 09:38 AM
BowSeR's Avatar
New User
Default Re: Fuel Pump (TurboInteg95)
and i would get rid of those denso plugs and just run ngk's cheaper and they work better. i ran the denso plugs and didnt get anything out of them.
Old Jun 15, 2001 | 11:03 AM
mod5's Avatar
Default Re: Fuel Pump (BowSeR)
I had the NGK spark plugs before (step 7) gapped at .03mm. Wasn't that great with the idle, it made my car's idle dip to 500rpm while driving.
The Iridium IK24 spark plugs seem to be working better, but my idle still dips. Personally I think the Iridium's are better.
Ok these are the Walbro fuel pumps I found, but I'm not sure which is right for my setup.
WAL-255 255 LPH In-Tank Fuel Pump $119.99
WAL-255HF 255 LPH High-Flow In-Tank Fuel Pump $139.99
nkerr09
Honda Motorcycles
Aug 3, 2017 04:24 PM
VspecSiR
Jan 29, 2005 01:55 PM
RACEPAK
Jun 5, 2004 01:03 AM
DaDaShT
May 28, 2003 10:02 PM
E-spec Tuner
May 7, 2003 02:05 AM
