Mitsubishi Eclipse Injectors
Old Jun 18, 2001 | 11:06 PM
VaporTrail's Avatar
New User
Default Mitsubishi Eclipse Injectors
I was wondering if 1g Eclipse injectors will physically bolt into the stock injector bosses on Hondas? http://www.roadraceengineering.com has 550cc injectors for a really good price, so I'm wondering what pitfalls I might encounter. Tried a search and came up with nothing. Thanks.
Old Jun 18, 2001 | 11:13 PM
TurboInteg95's Avatar
Default Re: Mitsubishi Eclipse Injectors (VaporTrail)
I cant remember for sure but I believe they are different. someone correct me if I'm wrong.
Old Jun 19, 2001 | 02:03 AM
sgT's Avatar
sgT
Default Re: Mitsubishi Eclipse Injectors (TurboInteg95)
I was using stock 1g eclipse injectors for awhile.
cheap 450cc
Old Jun 19, 2001 | 05:20 AM
BeeT's Avatar
New User
Default Re: Mitsubishi Eclipse Injectors (sgT)
Was it just plug and play? I guess it can't be. Stock ECU can only support up to 310 or 320 right? But did the conectors just plugin?
Old Jun 19, 2001 | 06:33 AM
sgT's Avatar
sgT
Default Re: Mitsubishi Eclipse Injectors (BeeT)
plug and play
with my field at -30% i was able to idle, barely.
car ran decently still, and thats NA
Old Jun 20, 2001 | 09:26 PM
Marc's Avatar
The RC 550s basically drop into the Eclipse with only minor modifications to the fuel rail. About 10min work with a dremel. If the RC 550's drop in the Eclipse and the Eclipse 450cc drop into a Honda then.......
Vaportrail,
Any luck on the Profec B tuning/installation instructions?
Old Jun 20, 2001 | 10:20 PM
Default Re: Mitsubishi Eclipse Injectors (Marc)
are those eclipse injectors high or low impedance?
Old Jun 20, 2001 | 10:22 PM
Marc's Avatar
Mitsubishi uses peak and hold injectors.
Old Jun 20, 2001 | 10:35 PM
dammit
Old Jun 20, 2001 | 10:52 PM
Ray's Avatar
Ray
New User
peak & hold yes! So is it true I can run 450cc or 550cc and yank out my fmu??? and drive with stock fuel pressure? Would I need a AFC?
Sorry lotta questions but im really interested.
Old Jun 20, 2001 | 11:02 PM
Ray's Avatar
Ray
New User
Old Jun 21, 2001 | 04:49 AM
sohc_boy's Avatar
Default Re: Mitsubishi Eclipse Injectors (Ray)
chk this post "MDA" is doing exactly what u are thinking off doing, i wanna give it a try too.
https://honda-tech.com/zerothread?id=46130
Old Jun 21, 2001 | 09:42 AM
pagong's Avatar
450 Eclipse injectors will fit a honda fuel rail, but, you have to modify it alittle. You have to take your stock injector o-ring and fit it to the eclipse injector and it will work. But, you have to have something to control the bigger injector. I know your gonna be using Hondata soon right? so you should be okay
Old Jun 21, 2001 | 10:09 AM
R6Boy69's Avatar
Default Re: Mitsubishi Eclipse Injectors (pagong)
Anybody know what the Auto DSM injectors were? I have heard that they were either 350cc or 250cc. Anybody know?
Mxl973
May 2, 2017 01:08 PM
Charlie Moua
Jul 25, 2013 04:34 AM
SiR99
Aug 25, 2006 08:32 PM
Bintegra
14
Jul 29, 2004 08:11 PM
DIY_Racing
Dec 21, 2002 09:16 AM
