Limit on a d16z6 with greddy turbo kit
New User
Hello. I am just curious what the limits are on this combination. Right now I have the kit with I/C running 6psi with no other mods cept for exhaust and pulleys. What else could I do SAFELY to gain good hp? Later on I will just either get the motor rebuilt or get a GSR motor. But getting bored with this 6psi stuff
Re: Limit on a d16z6 with greddy turbo kit (sporter)
NO clue about the engine here. But I wouldn't mind knowing what turbo comes with the greddy kit. Is it the Td04h-15c-8cm^2 turbo that comes on the greddy miata kits or is it a different one?
what size IC? you can probably bump up the psi a few notches if you have the medium/large IC. how's your fuel? do u have aftermarket injectors & and fuel pump. proper tuning is the key here if you really do want to pump up the boost.
things you might want to look into: Larger IC, thicker head gasget.. just make sure you always have plenty of fuel and you tune that A/F ratio.
