puzzling but innteresting problem.. not in boost??? fuel related...
Ok, car runs great.. but coming up the freeway last night.. once in ventura and once by my place.. 5th gear.. rounding a turn on freeway with slight incline.. i was not in boost, but got on the gas a little.. ever so slightly...
air/fuel went totally lean.. car seemed to run ok, but wouldnt accelerate.. I got OFF the gas completely.. then back on the gas and it straightend it self out and ran fine... on the second time it happened.. it threw a code.. I have to check out the code and see what it is in the morning..
Does anyone really have to know what mods I have..??? i dont have all night to list them.. hahahahahah
Re: puzzling but innteresting problem.. not in boost??? fuel related... (GSRwBOOST)
It's probably MAP related or something, my check valve always has little quirks like that. If they dont quite open fast enough or close enough or whatever it can mess up your computer. once you get the code it will be easy to tell. my car does that once in awhile in 1st gear. It seems I hit a certain throttle position and it just doesnt accelerate then I just press the gas a little bit more and it clears up and goes.
Flatland2D
07-28-2007 10:37 AM
sodacan33
06-25-2004 10:20 AM
