Sleving a broken block.. for my turbo project.. HELP
hey all i riped apart my friends old b16 engine ... i was going to use his block and get it sleeved...( with cast iron sleeves.. ) but he blew a piston #2 and also there is a small crack .. runing downwards about 1cm long from the top of cilinder #2.
does re sleeving fix this crack up.. or is this block as good as dead now ?
i wish i could take photo's of it.. but.. the block is still at my mates place...
Regards James
Regards James
Re: Sleving a broken block.. for my turbo project.. HELP (BLKCRX)
If you get GE sleeves it completely replaces the stock sleeve. As long as the block is not cracked, the sleeve could have a giant hole in it and it wouldn't matter.
Re: Sleving a broken block.. for my turbo project.. HELP (2K_TEG)
yeah the block is fine. just the Cylinder wall is cracked.. at the top..
humm but i an't goin GE sleeves. im going a custom sleeve job.. out here in Australia...
i guess ill have to ask them.. how there going to sleeve it..
Regards James
Regards James
Yeah Golden Eagle will take it even if it looks like this
http://imglib.************/index.cgi?...wimage&id=3179
Picture courtesy of Dustins site. I guess he was a little bored and the Goldschlager was runnin through his veins!
[Modified by 93LSivic, 1:08 PM 4/4/2002]
Re: Sleving a broken block.. for my turbo project.. HELP (01geeser)
sweeeeeeeeeet
i hope... this custom sleeving place out here in Australia... sleeves as good as GE.. if not ill have to save for a GE block...
the dude quoted me 550$ (aust) around 225$(us) to totaly work my block and resleve it with cast iron back to original specs... he jsut did'nt describe to me how he's going to do it.. well ill call him in a few hours and ask him.
mean while im going down now.. to the workshop.. and start installing maxrev !! oh yeah baby !
Regards James
Regards James
dustin was bored or something
Re: Sleving a broken block.. for my turbo project.. HELP (Boosted Ego)
Make sure the guy is using iron ductile sleeves if you want stronger ones. He just might be putting in oem replacments.
Re: Sleving a broken block.. for my turbo project.. HELP (DarksideDC4)
For all you skeptics out there here's the story behind the picture.
That is my old block. It was utterly useless do to corrosion in the water jackets (electrolysis is of the devil!!). So, we took our aggression out on it (see pictures). Afterwards, we needed to dispose of it.... So we eliminated all traces back to me and threw it away. Hence the removal of serial numbers.
The End
Stay tuned next week for the story about this pic......
The End
Re: Sleving a broken block.. for my turbo project.. HELP (jeremyG2teg)
If i had a motor that bad, i would have burried it. Put it in the back yard in a box w/ a headstone.
