Taping the oil pan.
Old Apr 3, 2002 | 08:18 AM
Evil EG's Avatar
Default Taping the oil pan.
I don't have a welder so what would you recommend for connecting the oil return line to the oil pan. I was thinking about drilling a hole and taping it thenscrewing a fitting in and connecting the line to a fitting.
Someone told me liqued weld...but dosen't that stuff break easy?!
-thanks
Old Apr 3, 2002 | 08:29 AM
b18b98's Avatar
Default Re: Taping the oil pan. (BVM)
i remember someone here used JB weld and it was A ok. I forgot who though. Why can't you find a welder? You can just go to any muffler shop and they'll do it for like 10 bucks.
Old Apr 3, 2002 | 08:35 AM
racerxadam's Avatar
you can use a bulkhead fitting. look at anplumbing.com or bakerprecision.com to see what they are. its basically a fitting that will go through and then use a nut to secure it on the inside.
would suck if the nut came loose and it might not seal very well but its an option
Old Apr 3, 2002 | 09:30 AM
DeeJay's Avatar
New User
JB weld worked like **** for me. I drilled a 1/2 hole in my pan and used a 1/2" npt - 5/8" barbed brass fitting. I've had no leaks and i think you would have to cut the fitting off to get it off again.
Old Apr 3, 2002 | 09:35 AM
Smashback's Avatar
Default Re: Taping the oil pan. (DeeJay)
My JB Weld oil pan fitting broke and I am a pro at using it.
Old Apr 3, 2002 | 09:46 AM
ion_four's Avatar
Default Re: Taping the oil pan. (mplex2000)
Maybe your feed line was too tight, or it hit something...if you read the package they give examples of fixing cracked diesel motor blocks with that stuff!...I think it could handle an oil feed. That's what I'm going to use, though it did seem sketchy at first.
92HB_HB's Avatar
what??? a story about JB weld failing!!??!! i better report this to JB WELD!!!...
Old Apr 3, 2002 | 09:50 AM
CovertFI's Avatar
Default Re: Taping the oil pan. (92HB_HB)
i used jb weld to attach a brass pipe to my flang. works great!!
Old Apr 3, 2002 | 11:43 AM
maxim's Avatar
Default Re: Taping the oil pan. (CovertFI)
I drilled and then tapped a hole because no one wanted to weld anything to an aluminum oil pan(I'm glad nobody did). I used a pipe fitting(threaded on both sides) and taped the flange that came with the kit and it works ok, but I wouldn't recommend it. Find another oil pan and drive to any location to get it welded, you will be glad you did.
Old Apr 3, 2002 | 12:15 PM
SilverLudeSi's Avatar
New User
Seriously, just go to any muffler shop and pay 10-20 bucks to have it welded. I know jb weld works good for people, but since its so easy why not just be sure its not going anywhere and get it welded for real?
Old Apr 3, 2002 | 01:33 PM
SIK IN DA HED's Avatar
New User
Default Re: Taping the oil pan. (SilverLudeSi)
i would recommend taking off your oil pan and getting it welded at a shop. its inexpensive. then, after the weld... apply some jb weld and make sure that **** is welded clean. i had mine welded and it leaked over time. i just applied some jb weld as well as some weld compound and it seems to be holding up so far. welding it and applying jb weld to seal any future leaks is the way to go.
Old Apr 3, 2002 | 06:18 PM
Farnsrocket's Avatar
Default Re: Taping the oil pan. (dlplayboy)
weld it.
Old Apr 3, 2002 | 07:30 PM
int3gra's Avatar
Default Re: Taping the oil pan. (Farnsrocket)
i remember we used to fix cracked oil pans on Porsches at the dealership with JB Weld. JB Weld
jdmsiR20
Jan 11, 2007 09:04 AM
Boring
Welding / Fabrication
Mar 23, 2005 09:17 AM
B18c1turboedEK
Feb 21, 2005 10:32 AM
AF-b16a1
Aug 3, 2004 02:24 PM
DIY_Racing
Dec 20, 2002 09:39 AM
