which plugs are you guys using
Old Apr 7, 2002 | 05:46 PM
uneekcrx's Avatar
Default which plugs are you guys using
topic says it can you please tell me the part# and brand
i'm using ngk 7's....are these o.k?
Old Apr 7, 2002 | 06:12 PM
2000_Civic_Si's Avatar
Default Re: which plugs are you guys using (uneekcrx)
With Forced Induction (FI) most people run "NGK BKR7E" plugs gapped at like .030-.032 for factory ignition, and like .040-.042 for aftermarket ignitions. I hope this helps.
Old Apr 7, 2002 | 06:19 PM
uneekcrx's Avatar
Default Re: which plugs are you guys using (2000_Civic_Si)
are you sure to gap them to .040-.o42?...........why is this different for aftermarket ignitions..i've never heard that before
Old Apr 7, 2002 | 08:16 PM
uneekcrx's Avatar
ttt
Old Apr 7, 2002 | 08:53 PM
SlowB16's Avatar
Are they gapped the size you recommended for stock out of the box, or do you have to do that yourself?
Old Apr 7, 2002 | 08:58 PM
Smashback's Avatar
A bigger gap gives a "bigger" spark and with an aftermarket (high output) coil and/or ignition box it will be able to produce "more" spark than stock to "handle" the larger gap...
Sorry, best way I could think of to explain it
Old Apr 7, 2002 | 09:13 PM
SlowB16's Avatar
Default Re: which plugs are you guys using (mplex2000)
So do you need to do the gapping?? With a stock ignition the the plugs you suggested work without being gapped?
Old Apr 7, 2002 | 09:50 PM
SIK IN DA HED's Avatar
New User
Default Re: which plugs are you guys using (SlowB16)
dude... you should always double check the gapping on the spark plugs. dont always think that it is properly gapped right automatically. better to be safe than sorry. you can recheck the gap in under a minute with all the plugs out of the box. its that simple.
what MPLEX said is pretty much what it is. the bigger the gap... you more spark youll need. on a colder plug, youll need to gap it less for the stock ignition to provide a good spark. aftermarket units like MSD offer stronger sparks than stock ignition, so it can efficiently provide a good spark for larger gaps.
Old Apr 7, 2002 | 10:48 PM
SlowB16's Avatar
Default Re: which plugs are you guys using (dlplayboy)
Cool
Old Apr 7, 2002 | 11:15 PM
PyroVTEC's Avatar
New User
I've been using NGK BCPR7ES-11s for my turbo D16Y8, except recently, I switched to NGK BCPR6ES-11s... just wanna see how different they are really. I figured I'm running <7psi anyway, and the 7s started going bad after only 6000 miles (and I drive VERY hard...), so perhaps the 6s will last longer... Gap's about 0.030" - 0.032" or so w/ my Honda ignition.
Old Apr 7, 2002 | 11:42 PM
austrian type-R's Avatar
Default Re: which plugs are you guys using (PyroVTEC)
I´m using the same plugs and I keep the stock gap which is pretty low on this one.
Old Apr 8, 2002 | 04:49 AM
uneekcrx's Avatar
Default Re: which plugs are you guys using (austrian type-R)
so what should i be gapping my plugs at now that i've installed my msd ign. and btm?
Old Apr 8, 2002 | 06:56 AM
TURBOHB's Avatar
I use iridium IK-22 plugs for my car. They expensive though. But I like the results I got.
Old Apr 8, 2002 | 12:00 PM
uneekcrx's Avatar
Default Re: which plugs are you guys using (TURBOHB)
anyone?
Old Apr 8, 2002 | 12:14 PM
rtype11's Avatar
I use densi iridiums on the street, two stages colder than stock, I use beru racing plugs at the track, they are remanned champs or boasch that have a 360degree electrode. They foul real easy though, so only for track use.
Old Apr 9, 2002 | 05:13 AM
uneekcrx's Avatar
Default Re: which plugs are you guys using (rtype11)
i still need to know what to gap my plugs to if i have a msd ignition?
kte324
Mar 15, 2010 09:36 AM
Jcup315
Apr 18, 2005 06:08 PM
hondaeg8
10
Feb 4, 2005 04:37 PM
1990hondadx
Jun 9, 2004 07:40 PM
SlowB16
Apr 10, 2002 09:15 AM
