Fuel system Recommendations
Old Apr 3, 2002 | 08:08 AM
SpeedRacer00-667's Avatar
Default Fuel system Recommendations
I plan on running 10 psi on my b18c block, i have rc310's, drag inline pump, stock 12:1 fmu, does that sound safe? or should i get a 255lph intank pump w/ another set up? i would like to keep it as simple as possible.
thanks
[Modified by SpeedRacer00-667, 9:10 AM 4/3/2002]
Old Apr 3, 2002 | 08:51 AM
b18bturbo's Avatar
Default Re: Fuel system Recommendations (SpeedRacer00-667)
sounds safe enough.
Old Apr 3, 2002 | 03:02 PM
turboex's Avatar
im in the same boat as you man, tryen to figure out what is the best system besides a standalone.
Old Apr 3, 2002 | 08:10 PM
Default Re: Fuel system Recommendations (turboex)
would an 8:1 disc be better???
Old Apr 3, 2002 | 08:14 PM
dustin's Avatar
I don't see too many GSR + FMU + 10psi setups last too long on stock block...
Old Apr 3, 2002 | 08:58 PM
5gen-hybrid's Avatar
New User
Try a 6:1 fmu with the 310's
Old Apr 3, 2002 | 10:16 PM
SIK IN DA HED's Avatar
New User
310s and 8:1
Old Apr 4, 2002 | 08:23 PM
Default Re: Fuel system Recommendations (dlplayboy)
0k, so w/ a 8:1 disc w/ rc310's & inline pump or intank pump???
thanks
Old Apr 4, 2002 | 09:33 PM
b16ahybrid's Avatar
Default Re: Fuel system Recommendations (94hondahybrid)
Forget the in-line go with a in-tank.
Like i said above (5gen-hybrid) go with a 6:1 and the 310's.I tried runing a 8:1 with my 310's but under boost they were just flooding my engine with fuel.
Old Apr 4, 2002 | 11:01 PM
Smashback's Avatar
Default Re: Fuel system Recommendations (b16ahybrid)
Yeah my 310's and 8:1 on my SOHC has to be leaned out quite a bit still with the AFC. I'm sure you could get away with an in-tank high pressure pump (i.e. Walbro) only using 6:1 and running 10 PSI, but I think that it won't last a real long time. You really need fine tuning to run higher boost levels, not just a "dump more gas in when boost comes on" device (that's what FMU really stands for).
YellowPhoenix095
May 14, 2007 06:30 AM
Novtecdohc
Feb 16, 2006 03:26 PM
SIK IN DA HED
Apr 1, 2004 01:03 PM
B18badboy
Jan 12, 2004 10:57 AM
BoostedD15B7
Aug 16, 2002 05:10 AM
