Motec M4 orM48 to run 8 injectors ?
Old Apr 4, 2002 | 07:44 PM
bambooluv's Avatar
Default Motec M4 orM48 to run 8 injectors ?
I spoke with Javier from Jg today and asked Him if I should run the Motec M4 or M48 and He told me to run the M4 . I also specifically asked Him if they can support eight injectors and He said "yes." He told me to run 1600cc on all eight injectors which surprised me cause He told me that I was only gonna use about 50 to 60 % duty cycles on the injectors ( I was originally gonna run 1400cc for the primaries and 1100cc for the secondaries ) . Now I highly respect His Opinion As I have followed His work from day one and think he is one of the top tunners hands down in the industry . I would just like a little feedback from you guys as I have read on the motec site that the M4 only drives 4 injectors . So any help would be appreciated , and pics of the completed project car will be up soon .-Pdang
Old Apr 4, 2002 | 09:31 PM
bambooluv's Avatar
Default Re: Motec M4 orM48 to run 8 injectors ? (94hondahybrid)
Thanks man hopefully I can get some info tommorrow from one of the distributors down here.
Old Apr 4, 2002 | 10:24 PM
Smashback's Avatar
Default Re: Motec M4 orM48 to run 8 injectors ? (bambooluv)
Nice spamming popups on your website....you should ditch that crap!
Old Apr 4, 2002 | 10:36 PM
Gmedalion's Avatar
You can run 8 injectors with the M4. You coud run 2 groups of 4 or 3 groups of 3, anyway you want, but it just has to be sequential. The M48 is just easier to handle but the M4 is possible to handle 8 injectors.
Old Apr 5, 2002 | 07:27 AM
b18bturbo's Avatar
why are you running so much fuel. You just need one set of 1600cc -1800cc shuold be plenty for the methanol setup you are going to run around 60-70% duty cycle. What methanol needs is almost double of what gas is there. so i dont see most pepiple needing that much injector
Old Apr 5, 2002 | 07:44 AM
b18bturbo's Avatar
Default Re: Motec M4 orM48 to run 8 injectors ? (b18bturbo)
the way i calculated it is the 1600cc is good to around 580hp hp and the 1800cc will be good for another 100hp so i figure if you plan on hitting 680hp the 1800cc on methanol will be easier to tuen a single setof injectors than staged system
Old Apr 5, 2002 | 08:27 AM
bambooluv's Avatar
Thanks for the info guys yeah I think Ill try running just one set of injetors but 1800cc does rc even make those or would I have to resort to another brand . I think the highest they go is 1600cc correct me if im wrong . Viren how much where you taxing on your friends injectors on the ls motor .Thanks -Pdang
New site up soon thats just a test site right now no more popups with the new hoster .
Old Apr 5, 2002 | 08:28 AM
b18bturbo's Avatar
the injectors were maxed out a 76% those were 1600c pushing right on 500hp i know you can take a little higher but it runs out i am posivitve
poweredbyb16
Mar 30, 2010 08:09 PM
pokemon master
Feb 10, 2007 04:48 PM
H.A.R.T B18C1EG6
Jan 4, 2005 11:10 AM
chris@allmotor.net
12
Aug 21, 2003 03:30 PM
