checked my plugs today.....
Old Apr 7, 2002 | 05:11 PM
uneekcrx's Avatar
Default checked my plugs today.....
i checked my sparkplugs today...and all was fine except for my number 4 plug had a liitle white discoloration on it......what could have caused this and what could i do to fix it....here's my set up:
zc motor
92-95 greddy kit @5psi
fuel press. reg.
msd ignition w/btm
stock fuel pump
fmu
stocl injec...
i have an inline pump and some 310cc to put in just waiting for 8:1 disc for fmu
also i just installed the msd igniton and btm last night
but i also have my ignition timing retarded about 2-3 deg. i've been told that that can cause it to run hot which according to my egt guage it kinda has but i watch it closely.....and never let it go past 1500deg...........which i think is still too high....but i am going to advance my ignition timing now that i put the msd btm on....how much should i advance it and what do you guys think i should set the retard setting for?
i just want to be careful because i don't want to kill my motor
i'm also planning to turn up the boost to around 8psi after the fuel stuff is installed
-any help would be appreciated
-thnx
Old Apr 7, 2002 | 06:15 PM
shadowdawn's Avatar
Default Re: checked my plugs today..... (uneekcrx)
Just a quick question if you don't mind, What exactly did your plugs look like? (not the white one) the one that were "ok", all mine are white/grey tipped I'm waiting on inline pump and vortech recalibration unit and will probably be going with 310cc injectors also.
Old Apr 7, 2002 | 06:22 PM
uneekcrx's Avatar
Default Re: checked my plugs today..... (shadowdawn)
they were all pretty decent looking not any white/gray at all.....mainly a little black i think just from running rich......but i'm not sure
Old Apr 7, 2002 | 06:35 PM
shadowdawn's Avatar
I was told black or dark colored is ok, white/grey is lean... which is my case.
Old Apr 7, 2002 | 06:45 PM
JM Performance's Avatar
since we're talking about plugs...how do these look?
Old Apr 7, 2002 | 07:20 PM
*Boostwerks*'s Avatar
Default Re: checked my plugs today..... (00SilverLS)
I beleive the engine of those plugs is running lean.
The insulators are not supposed to be "white".
Good conditions(rich)= dark gray - light black
Bad(lean) = white - very light grey. may also have blistered insultaor.
Also make sure the motor does not idle for a long time before pulling the plugs.
Rev the motor in boost, turn it off immediatly, let the engine cool, pull plugs.
Old Apr 7, 2002 | 07:31 PM
Default Re: checked my plugs today..... (Bryson)
whys that?
Old Apr 7, 2002 | 08:15 PM
uneekcrx's Avatar
ttt
Old Apr 7, 2002 | 08:43 PM
dustin's Avatar
Hmmmm
White plugs are fine. Look closely at the insulators w/ a magnifying glass. Look for silver specs/flakes (very small) or black specs/flakes imbedded in the insulator. These are signs of detonation...
Dustin
Old Apr 7, 2002 | 09:53 PM
SIK IN DA HED's Avatar
New User
Default Re: checked my plugs today..... (dustin)
hey dustin... i think its about time to change your mod list.
Old Apr 8, 2002 | 04:47 AM
uneekcrx's Avatar
Default Re: checked my plugs today..... (dlplayboy)
so i'm probably ok?
Old Apr 8, 2002 | 08:31 AM
that way you can check if it's running lean in boost, and you don't get mixed results from the tuning conditions at idle!!
tegSB85
Apr 4, 2006 03:34 PM
DLOTYPER
Jan 28, 2003 11:19 AM
uneekcrx
May 28, 2002 12:38 PM
