car just died please help!!!!
Old Apr 6, 2002 | 12:47 PM
mannysir's Avatar
Default car just died please help!!!!
i have a 2000 turbo civic si b16a with drag kit, just finished install . running ok past couple of days. i was driving on the highway and i noticed my lights were getting dimmer until the car just died. also noticed speedometer wasn't working. what could the problem be? i've had check engine light on and checked it. it was code 41 and 65, which are my sensors but i don't think it has anything to do with this problem. it must be alternator but it's a new car with only 15000miles. please if anyone can help me, i'd appreciate it.
Old Apr 6, 2002 | 01:40 PM
csufweed's Avatar
Default Re: car just died please help!!!! (mannysir)
make sure all the grounds are in tact.
Old Apr 6, 2002 | 01:51 PM
mannysir's Avatar
Default Re: car just died please help!!!! (csufweed)
you think it can be just a bad ground. i messed around with the 02 sensor wires can that be the problem
Old Apr 6, 2002 | 02:37 PM
ElectronVTEC's Avatar
I heard through the grapevine from my close friend at Honda that some of the '99-'00 Si's had alternator problems. I'm pretty sure its not a recall, so I'm screwed as they won't warranty anything on the car any longer (wonder why...). I'd take the car somewhere for an electrical diagnostics test, have them check the alternator... HTH, EV.
Old Apr 6, 2002 | 05:04 PM
AutoboTxEK's Avatar
Default Re: car just died please help!!!! (ElectronVTEC)
code 41 is the primary o2 sensor...mines went out and I drove it for a while like that..nothing bad happened..know that when ur o2 is out, youll get smoking...and you'll be running more rich than usual...it MIGHT be your alternator..but check your distributor cap, rotor, and spark plugs/wires...that can be the problem also...but then again...also make sure that your ground battery is hooked up..haha...
Old Apr 6, 2002 | 05:50 PM
bacid's Avatar
why don't you just take it to TAPP and let him figure it out?
Old Apr 6, 2002 | 06:05 PM
mannysir's Avatar
Default Re: car just died please help!!!! (AutoboTxEK)
by the way i also had a code 15 3 days ago but went away do u think my ingnition system screw up something to my alternater
Old Apr 9, 2002 | 02:21 PM
mannysir's Avatar
oh my god i feel stupid hahahahaha it was my alternater fuse what a relief the only thing i did not think of .anyways thanks for the help
mandalorianjedi
Dec 19, 2007 11:46 PM
bigwang916
Apr 11, 2007 09:08 PM
4drH22Accord
Apr 4, 2007 11:02 AM
CTR-GSR
Oct 12, 2006 08:46 PM
projek_allmotor
Aug 12, 2002 04:56 PM
