pictures (large) of jrsc '00 prelude sh IN PIECES
New User
so, the car still doesn't run, nothing i could try made any difference. so i'm biting the bullet, having it towed to the shop, and going for a different fuel management system (440cc injectors + efi pms + interacq). if that doesn't make me happy, the car is history and an m3 finds it's way into my garage.
today i pulled the blower, fuel rail, fmu, and valve cover. getting the valve cover off requires removing a lot of ****. i was curious to see if the timing belt appeared to be correct, and it seems to my eye that both cam gears are still aligned. the belt itself looks great. does anyone see anything unusual in these pictures? my #4 spark plug seal was looking a bit bad, but it's been that way for a long time. i think i got a lot of degreaser down there one time and it corroded it a bit.
[Modified by schwett, 10:25 PM 4/6/2002]
1 Post
Re: pictures (large) of jrsc '00 prelude sh IN PIECES (schwett)
I dont know the history of your car.. but I thought you couldnt turbo or SC an SH. I believe the only way to fix it was to convert the OBD2 ecu to an OBD1.
Wil
Wil
Re: pictures (exospeedAMcrx)
Wil
Wil
the OBD conversion with resistor box is what 5G Luders need to do to be able to us the Hondata.
The only way to totally elimnate the ATTS problem is to disconnect it or remove it completely.
paloerch
02-15-2012 09:08 PM
