Coolant flow?
Old Apr 3, 2002 | 08:42 AM
2000_Civic_Si's Avatar
Default Coolant flow?
Hey, I need to know where I would get the most accurate reading for a coolant temp sensor. So let me know if I am right about this....Does the coolant enter bottom of the radiator then exit the top of the radiator? In that case I would want to put the sensor in the bottom hose...Correct?
I was going to drill a hole in the thermastat housing but the sensor is to long it would interfere with the thermostat. I also tried the factory sensor location but I cant get to it... No room for tools. If anyone has some ideas on the best way to do this, please let me know.
Old Apr 3, 2002 | 08:56 AM
Brian_92GSR's Avatar
New User
Default Re: Coolant flow? (2000_Civic_Si)
I'm pretty sure it is the other way around. Coolant leaves the bottom of the radiator into the block and out the head into the radiator. You want the sensor as close to the head as possibile. If you were to put it in a hose you'd want it on the upper hose very close to the head.
Old Apr 3, 2002 | 08:58 AM
sgT's Avatar
sgT
drill the coolant neck that comes out of the head.
Plenty of room to mount a sender there.
Old Apr 3, 2002 | 09:03 AM
Default Re: Coolant flow? (sgT)
OK, Thanks....Just to make sure I want the top radiator hose, as close to the head as possable...Is that right? Thanks for your help.
frankc
Honda Fit
Aug 13, 2018 05:03 PM
95DC2GS-R
Jul 1, 2010 08:05 PM
dogbiscuit
Oct 28, 2005 03:40 PM
Rival23
Oct 22, 2003 08:48 AM
thecorey
Mar 11, 2003 12:19 PM
