To everyone with boost
Old Apr 7, 2002 | 01:21 PM
speedy108's Avatar
Default To everyone with boost
Everyone with a GSR or an LS with a turbo on it:
How long has your car been running sinse the turbo was put on?
Are you running stock internals?
How much boost?
What is your fuel setup?
And what is the name of the kit you are using?
Old Apr 7, 2002 | 01:32 PM
SIK IN DA HED's Avatar
New User
Default Re: To everyone with boost (speedy108)
LS TURBO:
How long has your car been running sinse the turbo was put on? 1 YEAR
Are you running stock internals? YES
How much boost? 5-7LBS
What is your fuel setup? Vortech FMU 12:1, STOCK INJECTORS, INLINE FUEL PUMP
And what is the name of the kit you are using? DRAG3
Old Apr 7, 2002 | 01:52 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: To everyone with boost (dlplayboy)
Put Drag III on my 97 LS at 115K miles. Had:
6psi
Stock everything
Drag supplied inline pump and 12:1 Vortech
S-AFC
Spun a rod bearing at 118K miles.
Rebuilt with:
JE 9.2 Pistons
Eagle ESP Rods
JG Block Guard
Holley Hi pressure Intank pump
440cc Injectors
S-AFC
And a bunch of other stuff....
@18psi
Old Apr 7, 2002 | 03:04 PM
DIRep972's Avatar
Smarter than you
How long has your car been running sinse the turbo was put on? 6 months
Are you running stock internals? yes
How much boost? 5-9psi
What is your fuel setup? FMU + bosch inline + walbro intank + stock injectors
And what is the name of the kit you are using? Revhard
Old Apr 7, 2002 | 03:09 PM
Prelussion's Avatar
Default Re: To everyone with boost (DIRep972)
Might i add please post your HP figures and times.
Old Apr 7, 2002 | 03:40 PM
speedy108's Avatar
Default Re: To everyone with boost (Prelussion)
Yes, please post your WHP numbers and how much boost you are running to get that HP.
Thanks.
Old Apr 7, 2002 | 04:22 PM
speedy108's Avatar
ttt
Old Apr 7, 2002 | 04:48 PM
InfamousRS's Avatar
Default Re: To everyone with boost (shamoo)
What caused that? Was it due to the high millage. My turbo will probably go on with about 93,000 miles, im a little worried about the higb miles on it.
Old Apr 7, 2002 | 08:13 PM
BlackGSR's Avatar
Default Re: To everyone with boost (BLK94RS)
Here's my view ...
With a turbo ... spend some money on the bottom end. Get pistons and rods and new bearings etc ... That with a properly tuned car (hondata) will last. Just don't be dumb and floor the car for like 2 minutes.
HT Username
15
Mar 9, 2005 05:15 PM
NightKids
May 5, 2003 09:41 AM
ridnmyhonda
Jan 29, 2003 09:35 PM
b_edson
Apr 23, 2002 12:55 PM
Tr0LL
Sep 14, 2001 10:54 PM
