F-MAX kit...thoughts, pros, cons, ideas?
Old Apr 6, 2002 | 11:04 PM
Jonathan_ED3's Avatar
Default F-MAX kit...thoughts, pros, cons, ideas?
it seems to be the most complete kit for what i want....b18b1 in 92 Civic HB...they actually have a kit for this setup.. what options should i order with it? my goal is low 13's on street tires. should i consider a different kit? i've heard the Drag kits aren't as reliable compared to the other kits. any and al info is appreciated.
Old Apr 7, 2002 | 12:44 AM
ImportReview
Guest
Posts: n/a
Default Re: F-MAX kit...thoughts, pros, cons, ideas? (hot_EF)
Bottom line.
If it has an FMU, its not what you want. And every turbo kit has smal, small piping..
no if, ands or buts.
Jeff
Old Apr 7, 2002 | 01:51 AM
MiraiZ's Avatar
FMAX + Standalone - 2 injector kit =
Old Apr 7, 2002 | 06:27 AM
sorry, but what's an FMU?
Old Apr 7, 2002 | 06:58 AM
Prelussion's Avatar
https://honda-tech.com/zerosearch reveals-- https://honda-tech.com/zerothread?id=158399
[Modified by Prelussion, 3:59 PM 4/7/2002]
Old Apr 7, 2002 | 07:04 AM
Aeka GSR's Avatar
New User
Default Re: F-MAX kit...thoughts, pros, cons, ideas? (Prelussion)
so i guess the search works now? heh.
Old Apr 7, 2002 | 07:05 AM
Prelussion's Avatar
Default Re: F-MAX kit...thoughts, pros, cons, ideas? (Aeka GSR)
worked good enough for me (although it usually doesn't work it's worth a shot )
Old Apr 7, 2002 | 09:41 AM
ekb18c's Avatar
Fmax is a pretty good kit, the only thing is that mf2 thingie. You know the extra two injectors crap! I like how the intercoolers that come with fmax kits, bolts right up the front cross member. And with their piping everying will fit and directly bolt up. No need to goto muffler shop later to weld on an extra piece of piping from the down pipe. Drag kits are just as good, so are rev hards etc.
Old Apr 7, 2002 | 01:47 PM
SIK IN DA HED's Avatar
New User
Default Re: F-MAX kit...thoughts, pros, cons, ideas? (ekb18c)
FMAX would be a good kit without the mf2 crap. just get a DRAG or REVHARD and go with a HONDATA.
FASTFIDDY
Jun 21, 2006 02:35 PM
egeeb16
Mar 3, 2006 08:11 PM
untitled
Dec 22, 2004 07:26 AM
2 point 0
Mar 18, 2004 12:34 PM
ZeRo
Feb 19, 2002 11:43 AM
