TURBO/CHECH ENGINE LIGHT
Old Apr 4, 2002 | 10:22 PM
turbogsr13z's Avatar
Default TURBO/CHECH ENGINE LIGHT
I JUST GOT A TURBO WITH THE CHECK ENGINE LIGHT AND I FIXED THE 02 SENSOR AND MY LIGHT WAS OFF AND IT CAME ON AFTER 5 MINS WHEN DIRVING ...I CHECKED THE CODE AND IT SAID IT WAS THE KNOCK SENSOR..I RESETED THE COMPUTER ECU EVERHTHNING WUT IS THE KNOCK SENSOR AND HOW CAN I FIX IT....HLP
Old Apr 4, 2002 | 10:36 PM
Smashback's Avatar
Default Re: TURBO/CHECH ENGINE LIGHT (turbogsr13z)
The knock sensor monitors for detonation.
You need to :
See how much boost you are running - are you getting enough fuel?
See how much boost you are running - is your timing set accordingly?
Are you running high octane gas?
Old Apr 5, 2002 | 12:37 AM
Default Re: TURBO/CHECH ENGINE LIGHT (mplex2000)
im running 6 boost i jus got my check vavle for the map sensor im using 91 premium and i put in my MSD inline fuel pump about two weeks along with ym vortech fmu and my turbo or blow off still flutters like a pigeon
Old Apr 5, 2002 | 12:38 AM
immortal's Avatar
Banned
did oil come out of your blow off valve
Old Apr 5, 2002 | 08:38 AM
CovertFI's Avatar
Default Re: TURBO/CHECH ENGINE LIGHT (immortal)
run some NOS octane booster and see if that helps also you should get an A/F ratio gauge
Old Apr 5, 2002 | 09:18 AM
maxim's Avatar
Just curious, why would that be related to the knock sensor. I have that problem, but I am positive it is blowby.
Old Apr 5, 2002 | 12:10 PM
Default Re: TURBO/CHECH ENGINE LIGHT (maxim)
wuts blowby??? and no oil from the BOV
Old Apr 5, 2002 | 01:15 PM
Smashback's Avatar
Blow by is oil that gets sucked into the intake tract of the motor either thru PCV valve or valve cover nipple.
Also, are you running standard plugs or did you get the 2 step colder plugs? If not, you should.
Old Apr 5, 2002 | 04:06 PM
im using bosch platnum plugs with the one tip and ive had em for about 2500 miles
Old Apr 7, 2002 | 03:38 PM
dohcvtec717's Avatar
ditch thoes bosch, go get some ngk platniums and gap them colder. bosch and hondas dont get allong.
Old Apr 7, 2002 | 06:38 PM
2000_Civic_Si's Avatar
Default Re: TURBO/CHECH ENGINE LIGHT (dohcvtec717)
Get some "NGK BKR7E Spark Plugs" from the local Auto Store. Also, throw some octane booster in there too. See if the car runs better. Those items should help.
bak lee
Jul 26, 2005 08:58 AM
dominate9
Dec 29, 2003 10:20 PM
luderone
Oct 2, 2003 03:50 AM
