revhard kit
Old Apr 4, 2002 | 09:17 AM
uNF$@#!'s Avatar
Default revhard kit
i currently own a stock b18c5 motor,
and i'm looking in the department of buying a turbo kit for it.
but i'm pretty much a newbie when it comes to FI.
I was thinking of purchasing a revhard kit, but what else would i need? a turbo timer...
i'm aiming for 8-10 psi of boost.
Help! or better yet, if someone could give me a link to llearn about what i need/etc. that would be best!
TIA
Old Apr 4, 2002 | 09:21 AM
TurboTypeR98's Avatar
New User
Default Re: revhard kit (00-0187)
If u want 8-10psi of boost u should lower your compression by either a headgasket or build the motor up with lower compression pistons.
But it all really depends on how much u want to spend.
Old Apr 4, 2002 | 10:20 AM
newsense's Avatar
New User
You will need to purchase:
A clutch
Gauges
An ignition system
an air filter (Revhard doesnt come with one)
turbo timer is a plus but isnt necessary
to run 8-10psi safely on a type-r motor you will need:
310cc injectors + v-afc + 8:1fmu or
idealy a standalone with 440cc+ injectors
and a good boost controller
Old Apr 14, 2002 | 06:56 PM
uNF$@#!'s Avatar
Default Re: revhard kit (newsense)
forgive the newbie question, but what is an FMU? and thanks for the help newsense
Old Apr 14, 2002 | 07:06 PM
BYT's Avatar
BYT
fuel management unit...vortech makes nice ones
Old Apr 14, 2002 | 10:29 PM
RedRacer's Avatar
New User
My buddy has a RevHard stage II powered ITR. The boost levels you have in mind could be achieved on the stock internals, just as long as proper tuning is at hand with good fuel management. Just be cautious of who you have tune your setup, as my friends motor bit the dust 1 night in a race because it was dyno tuned that afternoon and I believe the shop had it leaned out to much.
After that he had the bottom end rebuilt with JE 9:0:1 and Eagle rods and now is running somewhere in the neighborhood of 15 psi. His name on here is Vonte'. It sucks that he is in Korea right now though for a year, on Military assignment.
T.Steele
Aug 10, 2012 07:47 PM
B18_Hatch
Jun 29, 2005 07:30 PM
fastsmurf04
Oct 21, 2004 08:48 AM
f22suzuka
Aug 3, 2003 06:15 PM
ITR1071
May 20, 2002 10:01 AM
