Bought a Garrett turbo at the junkyard. What are the specs?
Hi All:
While searching the junkyard today for a tranny for my CRX, I found an 84 Volvo with what looked to be like a Garrett turbo. It took me like 3 hours to get the manifold off of the head, but I took it and bought the turbo + manifold for $65.
Here is a pic of the info plate:
Where I can I find the specs on this turbo? It looks to be of a decent size and at first glance, I thought the exhaust flange looked like a T3.
Here are those numbers if you can't read them:
Part Number: TB0326
Customer Part Number: 13 26425
ATD Part Number: 466032-2
Serial Number: NB0783A
The tag says "Garrett" on it.
More pics here: http://www.muller.net/sonny/turbo
Thanks,
Sonny
[Modified by Sonnyballs, 3:12 AM 4/6/2002]
Part Number: TB0326
Thanks,
Sonny
Re: Bought a Garrett turbo at the junkyard. What are the specs? (Sonnyballs)
It looks like a straight T3. Probably a .48 Exhaust housing Stage I Turbine with a .42 A/R compressor housing! Is should be enough for what you are looking at producing.
Re: Bought a Garrett turbo at the junkyard. What are the specs? (TurbochargedSER)
Sonny
Here are few more clues after cleaning it up a little. I am not sure what everything means...particularly the "M" numbers. (??)
Do the dimensions of the exhaust flange look to be the same as those of a T3?
Sonny
Sonny
HEY! thats the exact same turbo i just put on my car. Yes, it is a standard t3.
.42 compressor
.48 turbine.
I've been trying to find a map for it myself.
.42 compressor
.48 turbine.
Re: Bought a Garrett turbo at the junkyard. What are the specs? (RioNinja)
.42 compressor
.48 turbine.
.42 compressor
.48 turbine.
Sonny
Mine was from a late 80s saab 900, but its the exact same turbo. Did you get the downpipe with it? It was super easy to weld up a custom downpipe using the stock piece.
Have you driven your car around with this turbo yet? If so, how does it feel?
Sonny
The wastegate actuator rod is only adjusted to 4psi. It gets up to full boost by about 3k. Its really not that big of a turbo, but big enough to make my car fun to drive again I dont have an intercooler installed yet, but after it gets here im gonna turn it up to about 7psi.
Awwwww how cute . It's a straight t-3, reminds of my old turbo I tossed over the fence at pick a part.
Re: Bought a Garrett turbo at the junkyard. What are the specs? (TURBOHB)
what size is the t3 off of one of those old merkur's. i'm going to pick one up for 100 on wed. anyone else know the size of the turbo on a daytona? is it t3 also?
