Help, oil pan tap leak
Already searched and printed some stuff. The oil pan is tapped for the turbo and the return line is leaking (I didn't do this) because it's just clamped on there with an o-ring and a rubber hoses. Any suggestions on changing this out and with what type of hose?
thanks.
thanks.
Re: Help, oil pan tap leak (Farnsrocket)
Easy solution: get a stainless steel braided line and Earls fittings. I have the crappy hose that came with the Drag kit, in fact, same situation as yours. You won't have to worry about heat or hose cracks with the SS line.
KC GSR
12-02-2003 02:09 PM
turbo Si
04-19-2002 04:27 PM
