Prepping a B18B for Turbo
Old Apr 4, 2002 | 11:32 PM
VoltageLS's Avatar
New User
Default Prepping a B18B for Turbo
I'm going shopping for a 97+ B18B (LS Motor) pretty soon...and I plan on going turbo in the future. What steps should i take to make a bulletproof block that can withstand at least 10psi before i drop the engine into the car? Thanks guys!
Old Apr 4, 2002 | 11:37 PM
93LSivic's Avatar
Default Re: Prepping a B18B for Turbo (VoltageLS)
Tuning is all you need for 10 psi on a stock LS block....nothing more
EDIT* Sorry, make sure that you atleast run a new water, timing belt, and maybe oil pump on the motor. It all depends on mileage and how hard that motor has been ran.
Other than that, stock LS engine can run on 10 psi all year long.....
[Modified by 93LSivic, 3:39 AM 4/5/2002]
Old Apr 5, 2002 | 01:39 AM
Newbie In A Teg's Avatar
Default Re: Prepping a B18B for Turbo (93LSivic)
I've heard of people running 7-9 psi on stock internals and blowing their motors..
I guess that goes back to tuning again.
Anyway, I'm planning on ls turbo as well. I did a search but didn't come up with much to work with.. anyway, for an ls, what compression pistons would be ideal to boost with for boosting say between and around 10-15 psi?
I'd also appreciate it if a few ls owners with successful turbo setups would post those setups here.
TIA
Old Apr 5, 2002 | 06:34 AM
ekb18c's Avatar
Default Re: Prepping a B18B for Turbo (Newbie In A Teg)
I would change the water, oil pump and maybe the timing belt. You should alwasy change these when dropping in a new motor. As far as running safe for 10 psi, I would get bigger injectors such as 310 cc. As long as you have enough fuel going and and the timing is right, it should last for a lil bit. If you really want it bullet proof then you should get it resleeved! It's worth it!!! And offcourse the usually stuff such as bigger fuel pump, a fpr, etd.
HH
Old Apr 5, 2002 | 07:36 AM
DIRep972's Avatar
Smarter than you
youll be fine with 10psi on stock motor as long as u have the fuel.. - DONT TRY TO RUN 10PSI W/ FMU AND STOCK INJECTORS.. I would reccomend pulling out a degree or two of timing at 10psi as well..
Old Apr 5, 2002 | 08:04 AM
ExospeedAMcrx's Avatar
Im getting the list of possible block upgrades up on the site soon.
Hopefully this weekend.
It will have all motor and turbo blocks, stage 1 to stage 4.
From piston upgrade to a fully sleeved block.
I hope I can answer your questions with that list and that will help guide you in the type of block you would need.
Check on it later this weekend. http://www.exospeed.com/store.htm
Wil
Old Apr 5, 2002 | 10:29 AM
SIK IN DA HED's Avatar
New User
if youre going to build it for turbo... thats a good idea. but the stock block can handle it. just slap the kit on your car... go for it.
Old Apr 5, 2002 | 11:27 AM
Default Re: Prepping a B18B for Turbo (dlplayboy)
The thing is for this summer, ill probably make only enough money to do one or the other. Either to build the block or to get the drag3 on stock internals. I was thinking it would probably be a better idea to have the block built first because if i got the drag3, i would have to be running it on the stock block for a fairly long time because of $$ reasons.. I'm still debating though.. I could get the drag3 first and get block upgrades one by one afterwards ..
If i was aiming for 10-12psi street driven and 14-16psi at the track, would I be good with 9:1 pistons and tuning or should I go lower? Also what brand/type of springs, titanium valves and retainers are known to be reliable?
TIA
Old Apr 7, 2002 | 01:40 PM
ttt
nelson999
Nov 4, 2008 12:48 PM
euroborn1
Oct 20, 2008 08:27 PM
mayhem87
Dec 23, 2007 07:02 PM
IS teg
Jun 1, 2005 11:36 PM
viprcr1
21
Dec 20, 2003 11:40 AM
