what compression ratio to go with?
Old Apr 7, 2002 | 08:15 AM
dontcare61776's Avatar
Default what compression ratio to go with?
i have a stock b18b.....cant decide to go turbo or nos. if i went turbo what would be a good compression ratio to go with? and with nos? about to rebuild block as soon as possible so if you guys could try and help me out.
thanks yall
Old Apr 7, 2002 | 09:27 AM
ekb18c's Avatar
Default Re: what compression ratio to go with? (dontcare61776)
thanks yall
Well it all depends on you and what kind of fuel managment you have. The higher the compression the faster spool with a turbo which equal less lag. However on that note, the higher the compression the easier it is to blow **** up if you dont have proper fuel management and timing. I personally like high compression and lower boost amts. Most people play it safe with something like a 9 to 1 compression on most forced induction cars. If you are planning to run around 7-10psi then i would say go with 10 to 1 compression.
HTH
Soon_2b_evil
Nov 16, 2003 07:41 PM
s0liDyNe
Jul 19, 2003 10:24 PM
Cyber ITR
Feb 18, 2003 07:37 PM
baonest
May 7, 2002 10:31 PM
