Fuel Pressure Regulator question..
Old Apr 4, 2002 | 09:30 AM
DIRep972's Avatar
Smarter than you
Default Fuel Pressure Regulator question..
I need a fuel pressure regulator that can:
1)allow u to adjust base fuel pressure
2)rises 1:1 under boost
3)bolts up to stock fuel rail
4)allows u to run stock fuel lines
does a fuel pressure regulator exist that qualify's in all of these catagories?
Old Apr 4, 2002 | 09:35 AM
dustin's Avatar
Default Re: Fuel Pressure Regulator question.. (DIRep972)
The AEM does all of that. It has received some bad press, but I have yet to have anyone confirm that it sucks.
BTW, all fuel pressure regulators rise 1:1 under boost
Dustin
Old Apr 4, 2002 | 09:36 AM
TurboSedan's Avatar
New User
Default Re: Fuel Pressure Regulator question.. (dustin)
I use the AEM FPR on my Civic and it works fine. As Dustin said, it will do all of the things you require so go get it!
Old Apr 4, 2002 | 09:57 AM
DIRep972's Avatar
Smarter than you
so why have they recieved bad press?
Old Apr 4, 2002 | 10:22 AM
stick's Avatar
i think the initial batch of fpr they sold had a faulty diaphragm which caused it to leak fuel. since then, AEM has corrected that problem.
I have the AEM fpr for over a year now and no probs with leaks.
plus its a direct bolt on
Old Apr 4, 2002 | 10:49 AM
redline's Avatar
Default Re: Fuel Pressure Regulator question.. (stick)
my AEM FPR has seen 130psi of fuel pressure with no issues
Old Apr 4, 2002 | 11:09 AM
Trigun's Avatar
Default Re: Fuel Pressure Regulator question.. (redline)
i recommend aem also ... a bit pricey but you don't have to modify anything to install it ... should take you like 10 mins max.
Old Apr 4, 2002 | 11:16 AM
TurboSedan's Avatar
New User
Default Re: Fuel Pressure Regulator question.. (Trigun)
Yeah, 10 minutes if you don't have to remove the throttle cable bracket like I did! On my D16Y8 it was not just a quickie job!
Old Apr 4, 2002 | 08:16 PM
TurboTegB18c's Avatar
Default Re: Fuel Pressure Regulator question.. (97CivicFerio)
Holley also makes one that bolts to the fuel rail. I use it with no problems at all. Here's the link http://www.holley.com/HiOctn/ProdLin.../f512-506.html
Old Apr 4, 2002 | 08:23 PM
turbosol's Avatar
Default Re: Fuel Pressure Regulator question.. (TurboD16Z6)
Is there anything wrong with getting a B&M?
Old Apr 4, 2002 | 08:24 PM
Arturbo's Avatar
Better than steak
25 Year Member
I was looking at the AEM and I'd be willig to give it a try. I have given it the bad press in the past but it looks pretty good now. Plus, its cheaper than the Aeromotive.
art
Old Apr 4, 2002 | 08:29 PM
lucas569's Avatar
Default Re: Fuel Pressure Regulator question.. (Arturbo)
art were on the same boat, from what ive read the aem is fine as long as you stick w/ low fp levels. the aeromotive looks so sweet though,too bad it costs so freaking much to get it installed correctly.i'm a broke *** fool, so i'm going w/ the aem for now.
Old Apr 4, 2002 | 09:27 PM
DIRep972's Avatar
Smarter than you
Default Re: Fuel Pressure Regulator question.. (lucas569)
what do u consider to be high fuel pressure levels?
amazinspiderman
Feb 1, 2006 01:11 AM
chinners10
Jan 28, 2004 05:52 PM
LBR92DA-T
Dec 25, 2003 02:46 AM
