Vaccum/Boost
Old Apr 6, 2002 | 05:21 PM
Evil EG's Avatar
Default Vaccum/Boost
Im hooking up my vaccum lines from the wastegate, BOV, Boost Gauge, and the turbo.
Can someone tell me what all of these hook up to and where.
Old Apr 6, 2002 | 08:08 PM
rioninja's Avatar
Default Re: Vaccum/Boost (BVM)
Buy some t fittings, and tap into the vacuum lines for your vapor purge valve or fpr.
Old Apr 7, 2002 | 10:57 PM
Evil EG's Avatar
Where do i connect the boost line on the wastegate too?
Where do i connect the BOV line to?
Where do i connect the vac tube on the wastegate to?
Where do I connect the boost line on the turbo to?
-Thanks
(Yes Yes Im dumb )
BTW I have the DRAG III Kits
00' GSR
Old Apr 7, 2002 | 11:06 PM
SlowB16's Avatar
Like this....
from manifold to fpr---------- T -------T-------T--------T--------- into fpr
each tee is a different vacuum source, if you need more than that, make more....very simple....get some 5/32 inch vac line from any parts store
[Modified by SlowB16, 8:06 AM 4/8/2002]
Old Apr 8, 2002 | 12:54 AM
PrecisionH23a's Avatar
Wastegate + Turbo---------
If you are not running a boost controller, you will only have 1 hose coming from your wastegate (brass side fitting) connecting to the side of your turbo (side brass fitting on compressor side of turbo).
BOV----------
Connect this line using a plastic T to your FPR (fuel pressure regulator line)
Boost Gauge line----
plastic T this line into any vacuum source, you can use any lines coming from your intake manifold.
I have a page with turbo install directions on the h23a motor if it helps you out. good luck http://people.clemson.edu/~averma/Pr...o/Tinstall.htm
Lao17
Apr 2, 2011 05:28 PM
tundra2000
Sep 26, 2010 06:42 AM
1cammerjammer
Oct 22, 2009 10:04 PM
draconx
Mar 15, 2006 06:03 AM
VanHonda
Jun 8, 2003 04:01 AM
