HOW FAST?
Old Apr 7, 2002 | 12:54 AM
djtriptronick's Avatar
Default JG84mm B18C1 35psi?
How fast do you think an EK HB will run 1/4m with JG84mm B18C1(up to 35psi-that's what they claim) and Portflow B16A head (turbo spec port, dual valve springs, tit. retainers, type-r cams), Type-r manifold, and which turbo (turbo kit), should I use, considering 00 SI tranny...
Thanx
[Modified by djtriptronick, 9:59 AM 4/7/2002]
Old Apr 7, 2002 | 12:55 AM
Default Re: HOW FAST? (djtriptronick)
Daily driven?
Old Apr 7, 2002 | 01:40 AM
BlueShadow's Avatar
Default Re: JG84mm B18C1 35psi? (djtriptronick)
Thanx
I think it would only be crazy fast, not wicked fast... j/k
alll that stuff and you're not building up your bottom end
Old Apr 7, 2002 | 05:40 AM
Type-ARR's Avatar
Default Re: JG84mm B18C1 35psi? (BlueShadow)
not as fast as my car....... hehe
Old Apr 7, 2002 | 07:09 AM
Prelussion's Avatar
"JG84mm B18C1(up to 35psi-that's what they claim)"
if i'm not mistaken he's talking about his bottom end right there.
Old Apr 7, 2002 | 07:19 AM
BlueShadow's Avatar
Default Re: JG84mm B18C1 35psi? (Prelussion)
ohh I did't see that, it may be built I dunno, I just saw a long list of upper end parts and not one thing like rods or pistons in there (except for the one you just pointed out)
actually if he does plan on running some high PSI, I should have said "all that and no suspension setup?"...or something.
Old Apr 7, 2002 | 07:21 AM
AlphaKennyWun's Avatar
as fast as dustins car - see his sig
Old Apr 7, 2002 | 09:24 AM
Prelussion's Avatar
hehehe good recovery. But anyways, there wasn't a long list of block parts.
Old Apr 7, 2002 | 09:32 AM
InfamousRS's Avatar
Default Re: JG84mm B18C1 35psi? (SO3Burner)
Except for the 22psi part, that sig. is very believable.
Old Apr 7, 2002 | 11:26 AM
Erik_Pb_Foot's Avatar
New User
Default Re: JG84mm B18C1 35psi? (BLK94RS)
You'd definatly be in the 10's if you could get traction, you could drive, and your engine was tuned.
cm8719500
Aug 24, 2009 04:18 PM
dc2monkie
Sep 24, 2003 04:31 PM
sleepyhamsterlx
Jul 13, 2003 10:11 PM
smoothludey2
Sep 11, 2001 07:27 AM
