AEM EMS possible on non-obd vehicle?
I'm curious as to whether anyone has used the new EMS in a non-obd aplication. I know there isnt one available that would plug in,
What about with an OBD-1 conversion cable? would finishing the conversion to OBD-1 be needed? Or would a non-obd dizzy be usable?
Guest
Posts: n/a
Re: AEM EMS possible on non-obd vehicle? (RioNinja)
I researched it a little bit 'cause I'm non OBD. I think the only way to do it (short of converting to OBD1) would be to use the race version and configure all the sensors and wiring yourself. But I was told the race version is not available yet.
Re: AEM EMS possible on non-obd vehicle? (filetofit)
you can get an adapter to go from OBD 0 to an OBD1 ECU plugs.. then you can reconfigure the crank trigger to accept the 16 tooth crank position sensor in the ECU or change to an obd1 distributor. HTH
jason
jason
Ben for the price of the aem. You should look into hondata or haltech. Then you could use your ecu and dizzy. Less of a headache.
darrenVT
Engine Management and Tuning
18
09-30-2008 09:18 AM
