Intercooler End tanks design...
Old May 19, 2002 | 01:47 AM
Flamenco-T's Avatar
Default Intercooler End tanks design...
Does the endtank design makes a difference, I mean if a square design flows less than ones with a slanted side or a rounded side like the HKS ?
I am comparing between the drag IC end tanks and the new rev-hard end tanks and I was informed by a very intelligent source that the design with a lil slanted at the top of the end tanks help flows quite a bit than the perfect square design, due the flow direction of air
I am trying to make endtanks for my IC....so any thoughts will help...
Old May 19, 2002 | 01:51 AM
sgT's Avatar
sgT
Default Re: Intercooler End tanks design... (Flamenco-t)
logic would assume that if you "funneled" the air into the exit side then it
would flow better.
Old May 19, 2002 | 01:56 AM
Flamenco-T's Avatar
Default Re: Intercooler End tanks design... (sgT)
true...but do you think it will help on the inatke side too...
faster flow to the IC form the compressor
Old May 19, 2002 | 01:57 AM
sgT's Avatar
sgT
i think so. having the volume change slowly probably helps
Old May 19, 2002 | 02:02 AM
Flamenco-T's Avatar
exactly, instead of having a huge rush of air at one time, I guess velocity stack they use on regular NA intake has something to do with it
Old May 19, 2002 | 02:41 AM
inspyral's Avatar
Sqaured endtanks aslo cause more turbulance. The "slanted" designs help direct the air smoothly in and out of the core.
Old May 19, 2002 | 02:46 AM
BlueShadow's Avatar
**BlueShadow rolls up his copy of Maximum Boost and hits Flamenco upside the head with it**
hehehe, to add to the discussion a "baffled" in-tank is the best design. If you check out MB, CB states that the baffles will evenly distribute the air across the entire height of the IC.
EDIT: so the most ideal setup would be a baffled in-cap and a "funnel" shaped out-cap.
look in pg 60 of your copy of Max Boost.
[Modified by BlueShadow, 11:46 AM 5/19/2002]
[Modified by BlueShadow, 11:47 AM 5/19/2002]
Old May 19, 2002 | 09:56 AM
Cramerox's Avatar
since your going to make your own end tanks- some people but baffels inside the tanks to help direct air and to lessen turbulance.
i read in "Maximum Boost" end tanks that funnel the air flow better than square tanks.
Edit: Dangit he beat me to it....well like he said
[Modified by Cramerox, 10:58 AM 5/19/2002]
Old May 19, 2002 | 10:16 AM
TheSwift1's Avatar
Default Re: Intercooler End tanks design... (BlueShadow)
once again, Maximum Boost comes to the rescue...
P.S. i read the same thing...
Old May 19, 2002 | 11:02 AM
tonydatyga's Avatar
Default Re: Intercooler End tanks design... (TheSwift1)
a bit OT, but does everyone have MB in paperback or is it also available hardback?
Old May 19, 2002 | 12:15 PM
Flamenco-T's Avatar
Default Re: Intercooler End tanks design... (tonydatyga)
all the ones I have seeen is in the paperbacks...
and yes I red it too...
Old May 19, 2002 | 03:59 PM
BlueShadow's Avatar
I was almost certain you had it, but I was wondering why you were asking. although there is no mention of it in MB, I believe an unbaffled incap would just shoot air straight to the exit. and a square end-cap will have a lot of turbulence from the air hitting a "wall" so to speak.
Old May 22, 2002 | 01:40 PM
ILOVEGIRLS's Avatar
so who makes the best design?
b20vcrxsir
Jan 14, 2017 09:14 AM
Race Egr
Welding / Fabrication
48
Jul 29, 2014 09:01 AM
AWOC
Jul 18, 2014 04:29 PM
streetimports
Dec 1, 2005 03:38 PM
stockhatch91
Nov 22, 2004 02:43 PM
