Fmax Turbo Need Help!!!
Old May 20, 2002 | 08:12 AM
cyberx's Avatar
Default Fmax Turbo Need Help!!!
ok i plan on buying a Fmax turbo for my stock CRX Si engine... but the thing is i dont know what needs to be done to install the turbo, do i need to advance or retard the timing on the engine, do i have to play with the idleing??.. what do i need to do other then just putting the turbo kit on the car, can i run the car with just the turbo put on with out any adjustments with no problem??? how do i boost up the turbo to be 8 lbs, or 10 lbs, or 20 lbs if i want it to go up that high?? what exactly do i need to do?? also i am going to leave the engine stock for a while, then i plan on rebuilding it fully with everything new in their........
Old May 20, 2002 | 08:30 AM
CovertFI's Avatar
Default Re: Fmax Turbo Need Help!!! (cyberx)
just bolt up the tubo and go. i would not go past 5psi on your setup. dont worry about how to boost more. you will find out once you look at the WG. good luck it is alot easier than it seems. everthing will click as you install it
Old May 20, 2002 | 10:06 AM
cyberx's Avatar
Default Re: Fmax Turbo Need Help!!! (CovertFI)
thanks, i was so stressed that i was going to have to pay like 1 G to get it installed professionally... i guess not, but what about the electronics?
wreckmaster678
Feb 28, 2008 02:29 AM
TVietEBoyG
Aug 14, 2007 04:30 AM
drew102
Jul 24, 2004 10:24 AM
Briman2021
Oct 28, 2003 08:34 AM
Cryptopsy
Apr 16, 2002 01:14 PM
