custom downpipe
Old May 19, 2002 | 01:47 AM
rjardy's Avatar
Default custom downpipe
has anyone had one made if so how did it work out? Correct me if im wrong but you can just buy a turbine housing discharge flange and take it to a muffler shop and get a custome peice bent up into shape right? Sorry if it is a silly question to some but im kinda new to all this FI stuff, but damnit if it isnt fun TIA
ROB
Old May 19, 2002 | 01:52 AM
Flamenco-T's Avatar
Default Re: custom downpipe (rjardy)
it is more difficult than you think....and most muffler shop will less likely to have the knowledge or ability to do so..
you have to think about the clearance with AC compressor and not to mention a litlle angle so it won;t hit the oil pan, but high enough to clear the ground...
most of the T3 turbine flange are a 2.5" and you'll need this and still retain your AC. you can flare it to 3" after it clear the AC...
but my best suggestion is to just find a used one, it'll save you a lot of headaches
Old May 19, 2002 | 01:54 AM
Flamenco-T's Avatar
Default Re: custom downpipe (Flamenco-t)
Also, most DP bend down immediately after the flange, so you'll need to be very creative to put the lowest bolt for the flange but still giv eyou enough clearance to work with the bottom bolt
Drag has a smart way of doing it, but PITA
Old May 19, 2002 | 02:06 AM
rjardy's Avatar
Does any one sell just the downpipe? i mean i would be willing to buy it new from someone. Do you know if ben at importparts or viren carry this item seperatly? its for a b-series block. thanks for all your help Flamenco.
ROB
Old May 19, 2002 | 02:08 AM
Flamenco-T's Avatar
do you already have everything else and you just shorted a downpipe ?
if so, just look thru classifeds or partstrader...if not tell me what you have, I can see if I can find one around here...
Old May 19, 2002 | 02:14 AM
rjardy's Avatar
I dont have every thing yet, but im just trying to get as much research down as i can. It will be a t3 and i want to run an external wastegate (obviously) and retain my a/c. So i think i will try partstrader.com and see what i come up with. Thanks agian. OH allso can you just buy them seprate/new from any one? If it is quite tricky like you say i may want to just go with a new one. What do you think?
Thanks
ROB
Old May 19, 2002 | 02:23 AM
Flamenco-T's Avatar
you may be able to buy a new ones separate from the kit
BTW, manifold design determine the right downpipe, what kind of manifold do you have ? you can almost fabricate any downpipe to fit any manifold, but try not put yourself to do that...PITA
Old May 19, 2002 | 02:30 AM
rjardy's Avatar
Havent bought it yet but i have a good deal on a drag manifold. Allso the manifold might place the turbo is a different positon from mani to mani right? thats why you mentioned? Allso i wonder how hard it would be to fabricate it my self from the flange and some creative pipe bending? Oh well i guess i will figure that all out. What downpipe are you running? oh yeah i dont wana sound dumb but whats PITA?
ROB
Old May 19, 2002 | 02:32 AM
Flamenco-T's Avatar
I used to run Drag DP, but I am going with Rev-hard 3"
PITA = Pain In The ***..
Old May 19, 2002 | 02:33 AM
Flamenco-T's Avatar
BTW, I fabricate a DP my self for my old Civic GSR turbo............................................. .................................................. ......................................
NOT PRETTY...LOL
Old May 19, 2002 | 02:36 AM
rjardy's Avatar
haa haa .....
ROB
NWDyno
Jul 30, 2016 05:55 PM
overvolting
Welding / Fabrication
Aug 29, 2010 02:28 PM
aalb1
Sep 3, 2004 09:16 PM
ZhaGg
Jul 12, 2004 10:38 AM
prjctCIVIC
Jun 25, 2001 03:25 PM
