High 14's with a SOHC turbo?
Running a T3 on my VTEC SOHC Del Sol Si, and 5-7lbs of boost, will I be able to hit high 14's? That is my only goal with this turbo... high 14's...will it be possible right off the bat?
Re: High 14's with a SOHC turbo? (OKSolSi)
you should be able to hit high 14's wit now prob wit the right tuning and maybe some slicks. when i had my 4dr civic non-vtec i was in the low 15's
I pulled a 14.63 @ 95mph with a GReddy kit and only 6psi, in a 98 EX coupe, so yes you should hit mid 14's no problem.
Re: High 14's with a SOHC turbo? (Mista Bone)
I would hope you could run 14's WITHOUT the turbo.
Jeff
Even with your basic I/H/E and slightly gutted would be pretty tough to get that overweight del sol into the 14's.. maybe if you had some good drag radials and launched like a mother ******.
racinskittle
07-06-2005 06:47 AM
racinskittle
33
07-19-2004 09:30 PM
TurboSedan
02-01-2002 09:18 AM
