ringing bell sound, think it is the clutch
this doesn't happen all the time but i get this ringing sound from the engine compartment. it never happens during accelration. only when at idle or just crusing. i find it always stops when i push in the clutch. so i think it has some thing to do with it. any thoughts would help.
Re: ringing bell sound, think it is the clutch (CovertFI)
hey...i get that exact same sound too...and it goes away when I push in the clutch...clutch seems to work fine, but it does get a little harder to shift into gears sometimes after driving for a little while...
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
i got a ringing bell sound recently and it ended up just being the metal ring that goes over the intermediate shaft at the tranny side.
Re: ringing bell sound, think it is the clutch (not so civic)
That happen to me back in high school when I was driving a Toyota Levin ....it was a cracked pressure plate
it was noticeable most in neutral (clutch released)...don't remember if I was able to hear while driving....but when I had my clutch pulled, a couple of teeth on the pressure plate was missing and it was cracked....
Re: ringing bell sound, think it is the clutch (quickspoolin)
If it sounds like crickets then it's probably your throw out bearing.
[edit- bent fork?]
[Modified by apexii, 8:54 AM 5/21/2002]
Re: ringing bell sound, think it is the clutch (X2BOARD)
since i got the turbo the radio is either off or you can hardly hear it!!
the only thing you here is a wisle and that damn ringing noise
colesd16
06-28-2004 08:22 PM
