Most Important 3rd guage?
Old May 20, 2002 | 10:49 AM
Teg4e's Avatar
Default Most Important 3rd guage?
After Boost/Vac and EGT (or A/F), what guage would be best to add for a car running 6-7 lbs. and around 220whp?
Old May 20, 2002 | 10:53 AM
CivicGSRTurbo's Avatar
Default Re: Most Important 3rd guage? (Teg4e)
oil pressure or fuel pressure
Old May 20, 2002 | 10:54 AM
Rory Breaker's Avatar
Id say Fuel Pressure.
Old May 20, 2002 | 11:00 AM
wonny's Avatar
oil - no/low oil pressure is a killer.
Old May 20, 2002 | 11:01 AM
VaporTrail's Avatar
New User
Default Re: Most Important 3rd guage? (wonny)
if he's running a FMU, loss of fuel pressure is a killer also. I'd go for them both, but if I had to choose, oil pressure.
Old May 20, 2002 | 11:08 AM
Default Re: Most Important 3rd guage? (VaporTrail)
go with the fuel pressure. The oil pressure is good to have but if you can only get one get the fuel
Old May 20, 2002 | 11:39 AM
tonydatyga's Avatar
well I'd take egt AND a/f, but between oil and fuel I think oil. The way I see it is if your fmu dies, you're fucked anyway. If you got an oil leak, you can detect and have time to prevent damage. Makes sense in my head.
Edit: If you det, take it as a hint/opportunity to set up a proper standalone
[Modified by tonydatyga, 3:40 PM 5/20/2002]
Old May 20, 2002 | 12:20 PM
int3gra's Avatar
Default Re: Most Important 3rd guage? (tonydatyga)
DIY Wideband O2
Old May 20, 2002 | 12:45 PM
CovertFI's Avatar
Default Re: Most Important 3rd guage? (int3gra)
well when you are low on oil your vtec will not kick in so your car will run like ****. so you will know before hand. i say fuel pressure especally if you have an fmu. also i say an a/f ratio gauge over the egt because the egt can only change so fast. you know what is going on as soon as you see your a/f go into the red.
Old May 22, 2002 | 08:06 AM
wonny's Avatar
Default Re: Most Important 3rd guage? (CovertFI)
Integra LS = NO VTEC
Get the oil and fuel. I had OIL, A/F and Boost.
The way I look at it, why not spend a couple bucks now instead of spending over 4 grand when your motor blows. I think I spent around 4 - 5 to get everything redone.
Old May 22, 2002 | 08:08 AM
DIRep972's Avatar
Smarter than you
DIY Wideband O2
I 2nd that!
sick93sol
Aug 7, 2007 02:53 PM
elesvtec
Apr 16, 2006 08:57 PM
drevinder
Jun 14, 2004 10:37 AM
Kutsuju_SLeePER
May 16, 2003 08:32 PM
JM Performance
Dec 17, 2001 06:35 AM
