Fuel Pressure, Timing, and Spark Plug Gap With NX EFI NOS Kit (35 and 50 Shots)
Old 05-20-2002, 11:05 PM
99CivicSi's Avatar
Default Fuel Pressure, Timing, and Spark Plug Gap With NX EFI NOS Kit (35 and 50 Shots)
I was wondering if anyone could help me out. I just installed a NX EFI Stage One NOS kit in my 99 Civic Si and have put in 1 degree colder plugs gapped at 1.2 mm (.040), put timing at 16 (as set from factory), and raised the fuel pressure to 44 PSI at idle. I took it out and ran the car and watched my A/F ratio gauge and it lit up two yellow bars and all of the green ones. Has anyone ever seen this happen before ? I also installed the 50 shot fuel jet and left the 35 shot NOS nozzle in the car. When I checked the plugs they were brownish gray i color but this was before I put the 50 shot fuel jet in it. After I did that and ran it again, I checked the plugs and they are black (too rich ??). Also, does anyone know what the O2 voltage should be at WOT with the NOS activated ? I have been told anywhere from .89 - .94
Thanks,
Robert
EBP 99 Civic Si
Old 05-21-2002, 04:00 AM
D Tranny Guru
Mista Bone's Avatar
Default Re: Fuel Pressure, Timing, and Spark Plug Gap With NX EFI NOS Kit (99CivicSi)
if you installed the autometer AF correctly, you NEVER wanna see yellow bars when spraying.
JDMDC4life
10-12-2006 02:18 PM
eagleclawracing
03-08-2006 01:01 PM
DarkBB4
11-04-2004 10:13 AM
98Kord
06-26-2003 07:23 AM
hondaeg5
11-28-2002 12:09 AM
Quick Reply: Fuel Pressure, Timing, and Spark Plug Gap With NX EFI NOS Kit (35 and 50 Shots)
