DIY-WB installed
Old May 19, 2002 | 11:38 AM
dustin's Avatar
Default DIY-WB installed
I wired the DIY-WB in and put my new 57 trim turbo in yesterday (Thanks Ben & DRAG!)
It shows 14.6-14.7 at idle and cruise in closed loop, and 10.9-11.5 at full boost. I hope it's right
I have a switch wired in that switches input to the ECU from the stock o2 sensor to the wideband if I want to use Hondata to datalog it. I haven't tried that part yet, though.
Here are some pics:
Dustin
Old May 19, 2002 | 11:47 AM
dustin's Avatar
Default Re: DIY-WB installed (dustin)
Oh, and I couldn't find a weld bung for the O2 sensor locally...
So my friend Kell found me a spindle nut off a 88-92 Suzuki that worked
Old May 19, 2002 | 11:59 AM
Trigun's Avatar
looks good dustin!
Old May 19, 2002 | 12:56 PM
inspyral's Avatar
Default Re: DIY-WB installed (Trigun)
clean install
Old May 19, 2002 | 01:01 PM
DIRep972's Avatar
Smarter than you
so does this mean u got a car running again? u gonna be happy again? cant wait to hear how the hondata tuning goes with the DIY-WB.
[Modified by DIRep972, 10:02 PM 5/19/2002]
Old May 19, 2002 | 01:03 PM
dustin's Avatar
Default Re: DIY-WB installed (DIRep972)
It's running again.
Old May 19, 2002 | 01:26 PM
SEFIxCivic's Avatar
dustin,
i dont think its a good idea to have it constantly plugged in like that without it being powered. without the heater element running on the wideband, carbon will build up pretty quick inside and shorten the lifespan of the sensor considerably.
[Modified by SEFI8LOxCivic, 10:26 PM 5/19/2002]
Old May 19, 2002 | 02:08 PM
paulzy's Avatar
Default Re: DIY-WB installed (SEFI8LOxCivic)
looking good Dustin...How much did the whole thing cost you in the end?
Old May 19, 2002 | 02:20 PM
DA666's Avatar
Default Re: DIY-WB installed (Slow_ass_4dr)
Old May 19, 2002 | 02:27 PM
tonydatyga's Avatar
everything still looks nice and tidy... wish I could even come close, but hey I'm budget.
Old May 19, 2002 | 04:05 PM
dustin's Avatar
dustin,
both of the sensors are always heated.
Old May 19, 2002 | 04:10 PM
SEFIxCivic's Avatar
good deal what DIY kit is that, and where can we buy it? thanks
Old May 19, 2002 | 05:16 PM
Quaalude's Avatar
looks good dustin...how much did the diy-wideband run u?
Old May 19, 2002 | 05:27 PM
Jared's Avatar
what was the total cost on that setup? id like to invest in such a setup. you build the controller and then buy the gauge and the o2?
Old May 19, 2002 | 05:33 PM
C-speed's Avatar
Default Re: DIY-WB installed (Quaalude)
This is clean:
Old May 19, 2002 | 06:19 PM
tegman2's Avatar
Dustin, Where did you get the db9 connector from? I cant find any locally.
TIA
Aron
Old May 19, 2002 | 07:09 PM
Jared's Avatar
Default Re: DIY-WB installed (94hondahybrid)
Yeah, where does the parts list come from? and instructions? What is the approximate cost?
Old May 19, 2002 | 07:11 PM
dustin's Avatar
Default Re: DIY-WB installed (Jared)
http://www.techedge.com.au
Old May 20, 2002 | 07:06 AM
GruvyTune's Avatar
New User
Default Re: DIY-WB installed (G3-TEG)
G3-Teg.
Nice job!
Is that one of the original DIY boards you have there?
Old May 20, 2002 | 01:26 PM
rioninja's Avatar
What did it cost you total in the end?
Old May 20, 2002 | 01:51 PM
Jared's Avatar
Default Re: DIY-WB installed (RioNinja)
btw, did you build or order yours?
C_Rock77
Engine Management and Tuning
May 11, 2008 03:41 PM
jeffy
Mar 21, 2008 02:36 PM
lsvtec101
Sep 26, 2005 06:58 PM
Buster T
Aug 31, 2003 04:34 PM
WhoNeedsVtec
Feb 25, 2003 11:29 PM
