Ghetto ignition timing help.
Old May 18, 2002 | 09:59 PM
echo999's Avatar
New User
Default Ghetto ignition timing help.
Ok, I've been running my revhard setup for about 7 months without any problems,
and I realize that I have never retarded my timing.
I just read the HOW-TO on C-speedracing.com, and it seems straight forward on how to retard my timing just by turning the distributor.
My question is how do I know any timing besides what is marked on the crank pully? 0 BTC, 14, 16, 18 BTC are the only markings available.
Also, correct me if I'm wrong, but 18 BTC is 18 degrees advance timing?
On my setup (Revhard, 12-1 FMU, inline pump, stock everything else), what should
my timing be (on the safe side?).
Old May 18, 2002 | 10:19 PM
shadowdawn's Avatar
Default Re: Ghetto ignition timing help. (echo999)
if you really don't have access to a timing gun simply loosen the 3 bolts, and move that sucker AWAY from the windshied, and towards you about 2-3mm... that will retard it a bit. Better safe then sorry.. I just advanced mine this way from around 12degrees up about 2mm... dunno what the hell its at now, but its still lower then stock.
Old May 19, 2002 | 02:28 AM
inspyral's Avatar
Default Re: Ghetto ignition timing help. (shadowdawn)
You can get timing lights with digital readouts that tell you the exact ignition timing advance. Or, there are others with advance/retard ***** that will delay or speed up the flashing of the light so that when you line it up with stock timing, it's actually X degrees advanced/retarded. 18BTC means your spark is happening 18 degrees before the piston reaches the top of its stroke.
mortificationrock
Jul 10, 2007 04:26 PM
gsrguy
Feb 7, 2004 02:10 PM
