How do you remove the turbine housing from a turbo?
Re: How do you remove the turbine housing from a turbo? (zojirushi)
Sonny
i actually took all the bolts out, the housing seems to be stuck on the CHRA. would a torch be the answer to free it up?
yeah but you want to be careful when you hit cast metals, even with a rubber mallet or a deadblow. i have to fasten the CHRA down then i can tap the turbine housing, i just dont want to mess up the oil inlet/outlets. we will see, this is on my spare turbo anyway.
Re: How do you remove the turbine housing from a turbo? (RavenGTi)
you just undo the 6 bolts (i think) in the center and then remove the metal brackets. and pull it apart. tap it with some thing to get it loose
Re: How do you remove the turbine housing from a turbo? (CovertFI)
yeah all the bolts are removed or as removed as clearance will allow. the housing is stuck on there. i might have to let it soak in something.
mine is stuck to i removed all my bolts on the compressor side andlossend all the bolts on the exhaust side. andshe won;t budge any sujestions? i tried tapping it maybe i need to hit it harder.
Re: How do you remove the turbine housing from a turbo? (bmcc72)
haha damn, this message thread is maaddd old....
ok, this is what i did, i used alot of liquid wrench, and a hammer. Just be careful when u hammer the thing. eventually i got the damn thing off. Actually it took me a few days to get the turbine off. haha
InTraining124
12-09-2008 07:39 PM
